switching sides - LSi15
just wondering if anyone has placed their LSi15 with woofer pointing inwards and tweeter out?
this is how mine is now...any pro/cons switching L->R and R ->L?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
bump...my 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
I have mine reversed as the bass was kind of thin otherwise. My setup has two large openings to other rooms near each speaker, so that might explain why it helped reversing them?Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
If the side firing woofers are facing each other, you seem to get more bass. If the side firing woofers are facing away from each other, you seem to get less bass, but a bit cleaner.
try both, keep in mind the bass your getting from firing the woofs in might be a bit boomy. might be cool at first, but will get old. Try it anyway, can't hurt. My 15's are a little too close to the wayy, but firing them in would aim them at my theater stack and subwoofer and probably be worse than being to close to the wall anywayLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
experiment with placement, try putting them a little closer together and backing off the toe in a skosh.
toe in is fine with the LSi's, but I dont think they should be aimed right at your head though.Living Room 2 Channel -
Nice cat!Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
Tweeters in or out?
We recommend tweeters to the outside. It is the woofers that anchor the imaging, and the tweeters that add the air, harmonics, etc. So with them to the outside the sound stage is a little bigger and less stacked between the speakers.
http://av123.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=185&category_id=36&manufacturer_id=0&option=com_virtuemart&Itemid=37
this is for a line source speaker...dont know how it applies to the LSi M/T/M arrangement.my 7.(1x4) HT setup
Buttkicker
i rearranged my front speaker setup
-brought the speakers 2 feet closer (from 10ft to 8ft)
-no toe
the voice of andrea bocelli has more "bottom end" and system sounds less "bright". I like it, soundstage is as firm as before the rearrangement...will post pics this pmmy 7.(1x4) HT setup
Buttkicker
Maybe you can place some small cabinets or boards next to those side firing woofers (at some distance away), that way the bass will have something to bounce off, increasing bass response.
my 7.(1x4) HT setup
Buttkicker
I turned them in and got a much better bass response.
Hey slowcar, I have my rears on the wall like you and used some of this stuff to hide the wires. Im only making a suggestion, and it will easliy blend in with your wall color. I can post pics of my own if need be, but heres what I found.
http://cableorganizer.com/wire-cover/
Edit: Pic of my Rti4s on B-Tech77s attached
Your setup is kicka$$ though, good on your for experimenting with placement. Hows that D-sonic treating those LSis?Shoot the jumper.....................BALLIN.............!!!!!
i like the way you are hanging the RTi4! i went from RTi4 to FXiA4 because i wanted the driver to face forward on the surround...
fixing the wiring mess will be a formidable feat...:D
this latest setup sounds pleasing to the ear - will be keeping it for awhile
taking the lsi to reference level with the d-sonic, it maintains composure with no evidence of the amp running out of steammy 7.(1x4) HT setup
Buttkicker
