Onkyo 805 setup
Gizmo99
I just bought the Onkyo 805 and I have some questions, maybe other 805 owners can chime in.
1) With my Yamaha 1800, I was able to set my FXI3 / FXIA4 to "small", therefore no base goes to those speakers (I think). Whats the equivalent setting on the Onkyo 805?
2) With my Yamaha 1800, it was able to detect the bass crossover which allowed me to turn up the cross over on my sub to max. On the onkyo 805, it doesnt seem like its able to set the cross over on the LFE. What cross over should I set on my SUB?
Thanks in Advance
Thanks in Advance
Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
"The more time you spend researching here, the less money you will have"
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
Post edited by Gizmo99 on
1. Its more advanced than large/small, you can set your xover at 40-50-60-70-80-90Hz for center, fronts, surrounds and rear surrounds.
2. In speaker setup(2.2), scroll down an you can set LPF for the LFE at 80-90-100-120. -
Are those crossover settings specific to the set of speakers I have? Do you have the same setup?
thanks1. Its more advanced than large/small, you can set your xover at 40-50-60-70-80-90Hz for center, fronts, surrounds and rear surrounds.
2. In speaker setup(2.2), scroll down an you can set LPF for the LFE at 80-90-100-120.Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
The FXi3 has a spec down to 50Hz
The FXiA4 also lists 50Hz as lower limit
Both have a -3db lower limit spec of 60Hz
If this helps ... so 60Hz might be a good number, or you might want to just tack on 10Hz and call it 70Hz as a good xover point for those surround/rears
Your LSi15's -3d lower limit is 30Hz -
Thanks Wizzy.
Whats the difference between "Direct Mode" and "Multi CH" on the 805?Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
Got me on that one ... have you checked the manual?
It won't hurt the speakers if you set the crossover frequency lower then your speakers can handle right? For example, the RTi8's do down to 30Hz so if I select Full Band it'll possibly send signals lower then 30Hz to it.
I know you won't hear anything and I'm almost certain it won't do anything to the speakers but I want to make sure first.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
Theoretically, no.
But - something to think about. The xover occurs in the pre-amp section of the receiver. If you xover at 30Hz or 40Hz, the amp never has to bother putting out those frequencies below 30/40
The lower end frequencies take more power. So, when you are making the amp push those frequencies out, you effectively make the amp work a little harder (assuming your source has those low frequencies)
So, you get less power from the amp before clipping starts to occur. At lower volumes, your amp produces more heat.
If you cut out the frequencies you won't get from the speakers anyway, you have more power for the high lowend, midrange and high end.
Also, some may say that if your speakers aren't worried about producing those lower frequencies, the midrange frequencies might just be "cleaner" -
That makes sense. All good reasons to use it. My 805 unfortunately doesn't have a 40Hz crossover setting though so I'll have to set it at 40 instead I guess.
Thanks wizzy!Polk Audio RTi8 Fronts
Onkyo TX-SR805
Sure.
Don't be scared to experiment with not using the xover. It's possible you may find it just sounds better letting the fronts produce the lower frequencies - depending on how well your sub does it's job, and blends in. -
gizmodo99 good purchase. hope u dont mind if i hyjack ur thread. i did my own thread but only got one response. i just bought a svs sb12+ to go with my stuff. i ran audessy. it still kept all my fronts at full band which doesnt allow me to set crossovers. LFE is at 80 and i have double bass mgmt on. i was expected to be wowed but i wasnt. i felt like some ancillary sounds were louder but did not "feel" anything. any thoughts. i watched dh4 and transformers.Home Theater
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
Did you set the low pass frequency filter to something?Polk Audio RTi8 Fronts
Onkyo TX-SR805
If you are referring to the SVS, you always turn it off or push it as high as possible if you are using bass controls.
As for X-over frequencies, I would use this ROT: 1 octave above the -10 dB point or 80 Hz, whichever is lower. For RTi8's, this would put it at 60Hz and 80Hz for the rest. Remember, being a ROT, it's just a good starting point. I certainly wouldn't recommend putting the X-over at the -3dB point though, especially if you have a good sub....There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
Direct mode usually means 2channel & multi channel means just that.Thanks Wizzy.
Whats the difference between "Direct Mode" and "Multi CH" on the 805?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
But when I use Direct Mode, I am hearing sound from not just 2 front but the sourrounds too.Direct mode usually means 2channel & multi channel means just that.Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
Are you playing a two channel source? As I understand "direct mode", it plays the dat it receives with no processing (Such as matrixing of channels, effects, sometimes your x-overs and speaker distances, all depending on the version)There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
I think that's Pure audio.
Direct mode: In this mode, audio from the input source is output directly with minimal processing, providing high-fidelity reproduction. All of the source’s audio channels are output as they are.
-From 805 manualPolk Audio RTi8 Fronts
Onkyo TX-SR805
Well, there you go then!
You know I sometimes wish there was some standardization with this gear. Everyone gives out the same names for things but means totally different applications!
Gives me a colossal headache.:(Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks, should have looked at that manual
Direct mode: In this mode, audio from the input source is output directly with minimal processing, providing high-fidelity reproduction. All of the sources audio channels are output as they are.
-From 805 manualReceiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
one word giz... AUDYSSEY.
i tried every setting known to man but could not get things to sound good and clean. ran the audyssey and now i'm legit. i'd like to say 'too legit to quit'.:rolleyes::p
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments.
