Speaker match question
Hello all ..
I have a Polk RM7500 5.1 setup (which is now discontinued) that I moved into my bedroom and would like to upgrade it to a 6.1. I have been searching for either a RM3600 or RM4600 center channel with no luck online. The RM3600 center was basically the same as the center in the RM7500 set, but had 3 1/2 inch speakers as opposed to larger ones in the RM4600. Does anyone know what speakers might be a good match for this set if I wind up not being able to find the original speakers?
I attached a pic of the set if anyone is curious.
Post edited by DavGins on
bump
