I'm the first Polkie to fix an Ipod Tube Amp
ben62670
ben62670 Posts: 15,969
edited February 2008 in Electronics
Well not really, but I think I am the first to blow one up:D:o
Ben
Post edited by ben62670 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Somehow I didn't find that too surprising coming from you DOC. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • ben62670
    I was just running some sine waves, and all of a sudden no output. At first I thought it was my sound card. I was building an active XO with a Burr Brown OPA134. Everything was fine. I was running at 90db (annoying in the higher frequencies), and instantly nothing! The wiring is just as clean as the out side. There is 142vac (72x2) which kinda surprised me. Also 35vdc on the LM type (11 pin) chip amp, and a dinky little transformer.
    Ben
  • disneyjoe7
    Well the 35vdc seems odd to me doc. The 142vac didn't surprise me as much where did you read this?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    disneyjoe7 wrote: »
    The 35vdc is normal for GC type amp, but the 72vac per tube kinda surprise me. Each tube has its own secondary.
    Ben
  • disneyjoe7
    Ben, can you place a signal on the input then scope it out where you lose it. But my thinking its the GC amp chip. I don't know just a 200 mile hunch.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    Apparently the tubes are "dual channel" like other sixes are. I swap tubes, and I have sweet tunes again.
    Ben
    SCompRacer Posts: 9,245
    Are ya gonna crank it up again, until it hertz?:D
  • ben62670
    I always screw up which amendment to plead. I usually quote the one "The right to keep, and arm bears":D
    Ben
  • disneyjoe7
    Ok old school tubes in the mix check Tube first. :)
    Glad you got working again, seem like an easy fix. This time. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    disneyjoe7 wrote: »
    I already have some cheap replacements on the way. FredV hooked me up with a site to get them cheap;)
    http://www.thetubecenter.com/index.html
    I am building a homebrew low voltage tube pre.
    Ben
