Help with Induction heating for steam
Natalie
Natalie Posts: 2
edited February 2008 in Electronics
Hi,
I'm working on a project that would require the ability to heat water into steam via electric induction, preferably DC or via AC converter if necessary.
I'm thinking a monotube design with an induction coil surrounding it that could produce steam from 2 quarts of water in say 30 seconds or less.
Anyone here have experience with that kind of design?
Thanks,
Post edited by Natalie on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Ok why not....
    Why "preferably DC or via AC converter if necessary"? Watts are Watts AC or DC so you will need "X" watts to steam 2 quarts water, I doesn't care if it was DC or AC power.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • SlowcarIX
    SlowcarIX Posts: 887
    if its going to be induction heating, you WILL have to operate in AC
    how about telling us more about your project...
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • cfrizz
    cfrizz Posts: 13,415
    Welcome to Club Polk Natalie.
    Good luck with your project. Are you into audio at all & have a system that we can also help you with?
    Cathy
  • disneyjoe7
    Oh yes, you need an audio system to post a question here. It's not like we can answer an non audio question then convince them Polk Rules or something later.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • cfrizz
    :D If people can ask questions about their homework assignments, questions about whatever she is asking about:confused: are certainly allowed.:D
    I'm glad you know what she is asking about Steve, cause I have no clue!:eek:
    disneyjoe7 wrote: »
  • daboyz
    daboyz Posts: 5,207
    Kinda funny she'd come here to ask that question anyway.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Generate steam using induction ?
    The heck with that approach ! Man up and build this SOB !
    Natalie Click Here
    Generate steam, and possibly rip a hole in the space/time continuim for extra credit. :)
    But in the meantime, Natalie, if you could post some specs on your project needs, we can probably steer you in the right direction.
    ...without knocking down air traffic below 5000 feet or killing anyone.
    :o
  • Willow
    Willow Posts: 11,340
    [QUOTE=cfrizz;792752 I'm glad you know what she is asking about Steve, cause I have no clue!:eek:[/QUOTE]
    I'm with you on this one Cathy..
  • pearsall001
    pearsall001 Posts: 5,384
    My electric tea kettle works great making steam. Just copy it's design. :D
    Other than that sound advice, I haven't a clue about what the hell you're talking about.
  • bikezappa
    bikezappa Posts: 2,463
    Induction heating works on the same idea as an electric transformer. The electric transformer uses induction to change the voltage outputs to the electronic part. That is it converts the 120 volts input to 240 volts or 6 volts output for example. However induction can also be used to heat parts in the out put stage.
    AC must be used. I would use the output coil to heat a graphite tube which would heat the water inside the tube and convert it to steam. Not a very good way to heat water by the way.
  • disneyjoe7
    bikezappa wrote: »
    Ok I was thinking resistive heating where AC or DC wouldn't matter.
    The link here http://en.wikipedia.org/wiki/Induction_heating indicates 5k to 480khz so this is why she stated DC is she thinking AMP with a 5khz signal.
    I'm thinking this much energy required in a short period house AC power 60hz rectified to a DC voltage then passed to a switcher for the 5khz output needed. Power needed I'm too lazy to bust out my engineer decoder ring buy say in the range of 10kw. YMMV
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ShinAce
    ShinAce Posts: 1,194
    Two approaches can be used. Switched DC, or sine wave AC.
    You will need a lot of power to do it, and some element to absord the inducted field. Heating a graphite tube sounds good to me, but your best bet is to do some low power testing with different 'heater' elements. Make note the heater is just a block of something sitting in the water. Soft iron will work well. Consider ripping apart a transformer(lots of elbow grease - LOTS).
    Your coil will need to be a large gauge(read 4-8 guage) coil passing huge current, or a high voltage coil with many turns of smaller wire(20-30 gauge). The smaller wire is not necessarily an advantage as secondary breakdown can occur if your potential gets too high. You would need to make sure the small wire has a fantastic dielectric coating.
    Good luck. Brazing optical components and building a large induction heater. At this rate, you'll cause the next big black out.
  • mrbigbluelight
    Natalie, are you there ?
  • charistian
    charistian Posts: 2
    Definitely use a single tube. I would use one with vanes on the inside to maximize surface area between the water and the metal.
    Get a copy of Davies & Simpson's Induction Heating Handbook through interlibrary-loan.
    See also: Induction Heating
  • Sherardp
    Sherardp Posts: 8,038
    My thoughts exactly, the OP never responded to any of the suggestions mentioned.
