power cord upgrade
jayman_1975
Could someone point me in the direction of a good power cord debate thread. I'm sure it's been beat to death on here but can't seem to find much. I am tossing the idea of putting an aftermarket cord on my Anthem amp as I noticed that the stock one is thinner than the cord on my DVD player.
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Arcam CD37
Vandersteen V2W
Post edited by jayman_1975 on
Check this out:
http://www.hometheaterhifi.com/volume_11_4/feature-article-blind-test-power-cords-12-2004.html
and this:
http://www.polkaudio.com/forums/showthread.php?t=28152&highlight=signal+magic+power
A good power cable is essential. I just replaced all of mine with Signal Cable power cables and I'm very happy. I believe that a good, thick, quality PC is all that is needed. No special voodoo or high dollar power cables are needed. -
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=181-902
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=181-900Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Don't forget the gold duplex outlet:p
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=110-439Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
C'mon now, everybody knows outlets don't make a difference.
Funny, I actually did change the wall receptacle, removing the original contractors cheap outlet that came with the house and installed a $5 heavy duty version made by Cooper available at Lowe's. Additionally, changed all of them on the same breaker, using the upgraded $2 Cooper's on the non HT outlets. The gold outlet is a nice touch for the no holds barred system.
Here is a link to a cheaper 14ga alternative
http://cgi.ebay.com/2-HEAVY-IEC-FILTERED-AC-POWER-CABLES-cord-audiophile_W0QQitemZ270208811065QQihZ017QQcategoryZ32830QQssPageNameZWDVWQQrdZ1QQcmdZViewItem[ -
thanx for the info guys...i think i'm gonna pull the trigger on an Audio Art cord. I have all Audio Art IC's and speaker cables so it makes sense. Thanx again.Onkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
Its filtered(ferrite choke), but is not shielded. $150 for the PE gold plated outlet is nuts.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I think this is the first cable thread that has not been besieged by people who yell out "CABLES DON"T MATTER!!!" It is kind of refreshing.
Wait. Cables don't matter? :eek: :eek: :eek: :eek:
:rolleyes:
It is refreshing.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I wish someone would have told me this before i spent alot of money on some good IC's and speaker cable.:DOnkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
I wanna see some platinum wires.
BLING BLING -
BLING BLING
I tried out a pair of 22k gold cables on my system. They sounded like pure gold.:p
Seriously. Very refined and delicate sounding. Not sure what platinum would sound like, though.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I agree Ben, $150 for the gold plated outlet to hook up to household Romex is nuts. I did try one of those 14ga cords from ebay and felt it was a nice improvement over the OEM cable. I'm pretty lucky, no hum or static that I can hear when operating the system.[ -
I built a really nice cable for my mains amp a few years ago using all Wattgate connectors, 20 amp IEC on the amp and and 15 amp NEMA for the wall. I used some really top quality wire I had from when I used to work for Audioprism about 12 years ago. I noticed an ever so slight difference.
Then I ran 4 sets of #10 THHN stranded wire that I had twisted in metal conduit over to my breaker box (about 80' run of wire) and installed 4 new 30 amp breakers in the box and put a double duplex receptical behind the equipment with 20 Amp Hubble duplex outlets, one circuit on each plug.... This took 2 days... And made a very good improvement.... I can't reccomend upgrading your wiring from your breaker box to your equipment enough....www.forceaudio.com .... We cut through the BS. -
wow better power cords make a difference i just thought audio cables only did?MY SYSTEM
RT3000P
CS400 (2)
FX1000
Sony ST-SA50ES
Sony TA-E9000ES
Sony TA-N9000ES (2)
Sony BDP-S570
Sony LCD 46"
Technics SL-QD2
Monster HTPS7000
Directv HDTIVO
PS3
Xbox360
Wii
