Help Computer Guys!!
wingnut4772
I have a Mac and I am trying to scan a document and send it to my bank. They need a signed letter. When I scan it and attach it, the letter keeps going to my Outbox saying it's unable to be sent. I know I am doing something wrong...
I got one error message back saying the file was too large when I saved it as a tiff file whatever that is.
I don't know what I am doing. I have never tried to scan something and put it in an email before...
--- The following addresses had permanent fatal errors
@yahoo.com>
(reason: 554 delivery error: dd Sorry your message to [email][/email]
@yahoo.com cannot be delivered because it is too large. - mta510.mail.mud.yahoo.com)
@yahoo.com>
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
Save it as a .jpg, or maybe a .pdf.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Features Yahoo! Mail Plus Yahoo! Mail
Message size limit 20MB 10MB
If they just have a regular account the limit is 10MB...remember that means body/attachment/header/etc. Scanned files with todays resolutions are usually huge....try scanning it at a lower resolution and see what your file size is then.The first rule of Fight Club is you don't talk about Fight Club -
yeah you are doing a hi-res scan, and it is exceeding the limit of yahoo mail which I think is 10mb? Redo the scan at a lower dpi, maybe even just a straight black and white scan, not color. And save again as a .jpg file.
And shadow beat me to it.....lol. -
How do I change the resolution?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
It should be in your scanner settings....just try a straight 100-200dpi scan. That should easily get you under the 10mb file size.
It says resolution is set at 200.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
change it to 100 if you have to.
Thanks. That seemed to work.:)Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
OK. Now I am not sure. It is not in the outbox saying it can't be sent but it's not in my Sent box either. The yahoo address is one of my accounts as a test to see if it went out and I still have not received it. I stored it as a PDF to finder and then to documents. I attached it as a PDF file and sent it...?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Easy, get rid of the mac and get a normal computer.
Save it as a .jpg then check the properties and see how large it is. That will let us know if it's a size issue. If it is, use your photo editor of choice to lower the resolution. There's usually a default setting for e-mail in the photo editor, use that and you're on your way."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
:eek::D LOL! Mark, that's not nice.:DBaggedLancer wrote: »Easy, get rid of the mac and get a normal computer.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
BaggedLancer wrote: »Easy, get rid of the mac and get a normal computer."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
So much for the 'intuitive' MAC.
Yahoo sucks too. Sorry Frizz. Open a Gmail accnt, and try it as a .jpg file as it has the highest compression rate of any of the filetypes mentioned, and it's universal.
Also, you must be scanning more than one page to exceed the limit. Try half of the pages, and attach it separately in two different emails.-Ignorance is strength - -
wingnut4772 wrote: »It says resolution is set at 200.
What's wrong with 200?
I hear you need to have at least that or better:D-Ignorance is strength - -
If it's a b&w letter, maybe try making sure you are scanning in b&w (mono) or grayscale and not color.
This will not only reduce the size of the scanned image, but also make compressing into JPG work better as there won't be spurious color info (like thirty shades of white you can't differentiate) -
I know for when I'm scanning with my scanner, I don't worry about the DPI settings. I just scan, select the area that I want within the scanner's software, and then I save as a JPG. However, when that window comes up, it asks me how much compression I want to use when saving in the JPG format. Depending on the purpose, I'll jack up the compression.
So for your purposes, you'd want to scan it and save it as a JPG, but bump up the compression so the file will be smaller.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Ok. I scanned it jpg to the HP photo edit deal and resized it for email. That finally worked. Why does it have to be so freakin' complicated? GAWD! I need to take some classes in this computer stuff. I hate being lost. Thanks for the help.:)Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
