The Great Shanling Gear Giveaway
Early B.
Early B. Posts: 7,900
edited February 2008 in Electronics
Well, not quite, but prices are so low I'm almost giving this stuff away.
My friend asked me, once again, to list his Shaling gear which consists of the renowned T-100 tube CD player and the gorgeous matching SP-80 monoblocks. The amps and the CDP have been modded (see below).
Since he wants them gone, I'm offering them at special Polkie pricing -- the CDP is $850 and the pair of monoblocks is $950. We'll offer a $100 discount if you buy both of them.
Pics can be found here: http://www.polkaudio.com/forums/showthread.php?t=59020&page=3
Here's the caveat -- LOCAL PICKUP ONLY in metro Atlanta area.
PM me if interested. Thanks.
These are the most beautiful components on the planet. Extremely wife-friendly. All components are in 8/10 condition with no major cosmetic issues. There a slight blemish on one of the monoblock’s transformer covers. Manuals are included.
The CD-T100 employs the latest in technology. Upsampling to 24 bit/96 kHz is performed using Crystal’s CS8420 sample rate converter. Four high-performance Burr-Brown PCM1704 chips do the D/A conversion while a second generation Pacific Microsonics PMD-200 decoder chip is used for HDCD decoding. The CD-T100 includes matched pairs of NOS Western Electric 2C51/396A audio tubes. The addition of the Western Electrics greatly improves the sound quality over the stock tubes. The tubes give the CD-T100 a detailed, lively, and musical presentation. The T-100 has volume control via the remote, so no preamp is needed.
The SP-80 monoblocks are rated at 50 wpc and have been designed to specifically match the CD-T100, both in aesthetics and musicality. These monoblock amplifiers are absolutely stunning to look at and built to the highest of standards. They are very quiet, fuss free and fill the room with a majestic sound that you just do not normally expect from an amplifier of this level. The SP-80 monoblocks have been modified by having the preamp section removed to simplify signal processing and allow for a cleaner sound. The T-100 has also been modified to include dual opa6027 on a BrownDog adapter. The monoblocks come with JJ Tesla E34L tubes with very low hours.
Here are some reviews:
http://www.enjoythemusic.com/magazine/equipment/0902/shanling.htm
http://www.6moons.com/audioreviews/shanling/T100_2.html
T-100 Specifications
Output Impedance: not specified – estimated below 300 Ohm RCA for tube amp and headphone, below 150 Ohm CD Audio
Frequency Response: 20Hz to 20kHz
Distortion: <0.002% (1kHz)
Signal/Noise Ratio: 110dB (tube output 102db)
Dynamic Range: 115dB
Crosstalk: <100dB
Output Level: 0~2.2V adjustable (remote volume)
Tube Compliment: four 6N3P, standard Chinese (compatible with WE 396A & 2C51)
Digital System: four 24 Bit Burr Brown PCM1704 DAC, PDM-200 96kHz HDCD Digital Filter, Crystal CS8420 upsampler for 96kHz upsampling
Transport: Philips CDM-1201 with Philips CD7 II servo circuitry
MSRP: $1,995
SP-80 Specifications
Use EL34, 6N8 and 6N9 tubes.
Output Power: 50Wx2
Distortion: <1%
Frequency Response: 18Hz-30KHz ±0.5dB
Signal-to-Noise:95dB
Tube Types: EL34 6N8 6N9
MSRP: $2,500
"God grooves with tubes."
Post edited by Early B. on
  • JimBRICK
    JimBRICK Posts: 1,543
    no pics in that thread
    found this though I'm drooling
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Early B.
    JimBRICK wrote: »
    Sure there is. See post #62.
