Gonna be rocking dual subs
Shizelbs
Shizelbs Posts: 7,433
Any tips on how to set them up?
I'm going to be running a pair of Sunfire True subs. Not my first choice, but due to everything else in the room, I am pretty locked into small size and few options for location. For now I was just planning on splitting the LFE out and running a sub cable to each one.
Post edited by Shizelbs on
  • Early B.
    Early B. Posts: 7,900
    edited February 2008
    Shizelbs wrote: »
    Yep, that's the ticket.
    Play around with placement.
    Will this setup be for movies, music, or both?
    "God grooves with tubes."
  • Sherardp
    Sherardp Posts: 8,038
    Should sound good bro, You may want to look around for a used Velodyne SMS-1
  • wingnut4772
    wingnut4772 Posts: 7,519
    Sherardp wrote: »
    Agreed. It makes a BIG difference.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    treitz3 Posts: 20,001
    The Velo SMS-1 is a godsend to the lower octaves and integration between the subs and mains. Dual subs sound great and with what I have experienced sound there best when placed in opposite sides of my room. When both subs are on one side the sound envelopes you but makes the side in which the subs are not located sound empty and lacking.
    In addition, subs that have different sonic characteristics can also make the system sound better, provided both are adjustable. For instance if one digs lower than the other, set the volume slightly lower than the other as to not get the boom at the bottom but add that subtle needed frequency to complete the spectrum.
    This is how my current setup is along with the SMS-1 and the sonics are quite nice to my ears. Placement with each sub is just as much key to the end result as the mains are and can make quite a change not only in frequency response in relation to the listening position, but to the sound stage as well.
  • hockeyboy
    hockeyboy Posts: 1,428
    You will never go back to a single sub is my prediction. CONGRATULATIONS!
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • Shizelbs
    Early B. wrote: »
    Mostly movies and games.
  • Early B.
    I'd start by setting the sub on each side of the seating position in order to get the full tactile effect. I'd also try setting them next to each front speaker, if possible.
    Do you have a pic of your room?
  • Shizelbs
    I need to take an updated picture of the home theater area. I can do that later this weekend, and then I'll post the pics.
  • Shizelbs
    OMG OMG OMG OMG, I got the new sub today. I don't have my Y splitter yet, but this is going to be awesome.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    Early B. wrote: »
    Speaking of tactile effect...just add these underneath your seat...
    Tactile transducers f/s at partsexpress. No afil. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-864
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jazzisnumberone
    jazzisnumberone Posts: 53
    rumble,rumble. that's how it's going to sound.
  • Shizelbs
    Well, it turns out the second sub is a dud. The seller is hella cool and he is going to pay for repairs.
  • beardog03
    beardog03 Posts: 5,550
    mmmmmmmmm...dual subs
    I still want dual subs...just alittle underfunded right now
    enjoy !!
    I`m sure you will !!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • kolyan2k
    kolyan2k Posts: 259
    question: if u connect both subs to lfe, dont u loose stereo subs efect ?
