Subsonic Filter
jazzisnumberone
jazzisnumberone Posts: 53
edited January 2008 in 2 Channel Audio
Can someone explain what this means(Subsonic Filter)? I have an older model (Onkyo integrated amp A-8067).And it works great.It may sound like an off the wall question but this inquiring mind would like to know.
Post edited by jazzisnumberone on
    treitz3 Posts: 19,992
    edited January 2008
    Hello. A subsonic filter omits or takes out the frequencies [generally] below 20 Hz on the frequency range.
  • jazzisnumberone
    edited January 2008
    This is for a 2 channel system. Should it be engaged?
    edited January 2008
    You have a Turntable or do you run a live mic through it?
  • wizzy
    wizzy Posts: 867
    edited January 2008
    Wow, blast from the past.
  • mulveling
    mulveling Posts: 505
    edited January 2008
    You only need to engage it if you're running a turntable source and your speaker's woofers are getting visibly slapped around during playback. By "visibly slapped" I mean you can see the woofer cones moving back and forth - normal audio frequencies move the cones too quickly to be visible.
    The most common source of subsonic noise is likely to be TT rumble, typically in the 6-10Hz region. Many phono stages have a built-in filter that starts around 10Hz and attempts to chop everything below that. So the switch possibly effects only the phono stage in your integrated, or it may be an external circuit (in case user plugs into aux from an outboard phono); depends on how it was designed.
    From a purist standpoint it may be deemed an unnecessary circuit, however if the slapping is too vigorous, though these frequencies are not directly audible, it could have impact on the overall sound and could potentially be bad for the woofers in the long run. FWIW my Benz phono has a built in 10Hz filter that's not defeat-able, and I'm glad it's there. Yet still, I can see some vibrations in the woofers when using my TT - I'm assuming it would be worse without the filter.
    I am sure the CD fanboys/girls will now generously supply a bounty of clever & humorous remarks about yet another vinyl quirk/hassle, but dammit it's still worth it to me and I still only love & listen to vinyl for 2ch :p:D
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • jazzisnumberone
    edited January 2008
    Not playing it that "hard". The system sounds wonderful. A compilation of older gear that has kept me mesmerized for a few years. I do have a TT( Dual CS 503) with a moving coil cartridge. Primarily for jazz music (albums and cd's).
  • jazzisnumberone
    edited January 2008
    Nothing(and i mean NOTHING) beats the sweet sound of vinyl. Spin on baby...
  • mulveling
    edited January 2008
    Quality older gear is truly a bargain paradise, if you know what to look for, or if you just get lucky! Most of the best 2ch audio stuff ever was conceived decades ago (IMO), and some of the stuff was really built to last. Heard some vintage 60's Eico 20 Watt tube amps a couple weeks back that made me think all the contemporary hifi amps I've heard (and owned) are way overpriced!
    Spin on, and enjoy!
    :D
  • jazzisnumberone
    edited January 2008
    I'd love to get my hands on a set of Bose 901's. Now there's "old" gear that would sound awesome.
    edited January 2008
    With the TT in the loop, you may want to run with the subsonic filter engaged. If you ever drop the needle accidentally while the volume is up, it just may save your speakers.
    One test you could perform is with the SSF disengaged, play an LP at concert levels and with the speaker grills off, take a look at the woofers. If they have excessive cone excursion whilst playing, turn down the volume, engage the SSF and see if the excursion reduces.
  • jazzisnumberone
    edited January 2008
    I will try that. things are a little quiet here so i will do it during the day when everyone is awake. Ty for everyone who commented. Long live VINYL....
