what do you guys think
crd2002
should I go with a rotel amp or a parasound amp not familiar with either as I have a cinenova grande 7 channel but want to set up a 2 channel rig just for music
Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
Post edited by crd2002 on
All depends on what other gear you plan on matching it up with.HT SYSTEM-
lsi 9's -
right now rti12 but will be geting the lsi15 hopefully soonHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100 -
Off the top,if lsi's are in your future,parasound.What 2-channel pre has your eye?
Not to say Rotel is bad,it's not,just not my cup of tea,thats just me though.HT SYSTEM-
lsi 9's -
looking at getting a sunfire III pre so in case I want to use it for hometheater later
the amp that is being offered is the Parasound HCA-1205A THX 5-Channel AmpHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
also matbe getting a Sunfire cinema grand 5 for 1200.00 what do you guys think is the best deal out of the 3 ?Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
The cinenova grande 7 you have is no slouch. It will probably smoke any Rotel amp with the exception of the 1090 and will probably give all but the Halo stuff a good run. What is wrong with the Cinenova that makes you want to replace it?
Venom -
no dont want to replace it I'm putting together a 2 channel rig just for musicHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
I'd leave the cinenova alone. It's a nice amp. You are looking, IMO, at a lateral move at best.
Plus, having those extra channels also makes biamping a cinch.
not getting rid of my cinenova using it for my new 2 channel rig since I changed my home theater from RTI12 to RTI8 and need a new amp for them will never get rid of my cinenova this thing is a beastHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
Sorry,a bit confused.Why are you looking at 5-7 channel amps for a 2 channel rig?
And why use the cinova in a 2 channel rig?Leave it doing ht,thats what it does best.Plus you would save more coin by buying a 2 channel amp rather another 5-7 channel amp.HT SYSTEM-
lsi 9's -
yes you are`right I do save more money buying a 2 channel amp but later down the road plan on setting up a second home theater and would have to buy another amp then so rather just buy a 5 channel now and use it for music and have it ready for when i do the second theater systemHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
If you have the chance to get the Sunfire combo, that is what I would do. All three amps will do the job nicely. So my choices would be: 1. Sunfire, 2. Parasound, 3. Rotel.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
thanks sunfire it is do you think 1200.00 is a good price for the sunfire cinema 200wpc ampHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
Absolutely! Go for it Crd!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I think the shift key and punctuation are awesome things. You should try them.
thanks done sunfire it is!!!!!!!!!!:DHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
Cool. Make sure you come back & give us pics & a review!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
was talking to Bill Ayotte and he pointed out to me another benefit of getting this amp is that now I can Bi-amp my 12 and that should give me even better sound on my 2 channel set upHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
Congrats on the new setup, and it was great to talkin you tonight... I can't wait to see how it works out for ya.
