SVS 25-31PC Plus vs. PB12+?
Serendipity
Hi,
For a HT application, is there any difference between the SVS 25-31 PC Plus and a PB12+ box subwoofer? I was under the impression that they should sound the same but I may be wrong.
P.S. My sealed 15" Dayton Titanic DIY sub is great for music, but I'm thinking something like the above SVS's would be better suited for HT...
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
The PB-12 would be about the same as the 20-39 PC Plus. It is tuned 5hz lower (and has a larger cabinet) than the 25-31.
Other than looks, weight and cost they should be about the same.
You know port position has to do alot with how well it will sound. High ceilings with a port up, might not sound as well as a port 4-6" from a wall. But it really depends on the room.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Go for the plus2 for more output in the HT.Shoot the jumper.....................BALLIN.............!!!!!
Thanks guys.
I was thinking about the 25-31PC Plus because it is cheaper than the PB12+.polkaudio RT35 Bookshelves
I'm surprised you don't build another sub for home theater like your Titanic. You would most likely be able to build a superior ported sub for less money than you are willing to spend on the svs. Don't get me wrong, I like my svs but it doesn't compare to my diy subs. Maybe building one isn't a possibility though, just throwing it out there!
Silversmoky -
I was going to build another sub, but then I read all of the SVS reviews about how they are so good for HT, and now I'm not sure what to do.polkaudio RT35 Bookshelves
Is money an issue? If it is, you can build a sub just as well as SVS for less than half the cost.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Better bang for the buck.
http://www.edesignaudio.com/edv2/index.php?cPath=2_41
You can also order them unfinished and finish it yourself."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Sure, I already did.
But how the heck do you build a cylinder sub?polkaudio RT35 Bookshelves
Sono tube, end caps, base plate, port and amp.
http://www.polkaudio.com/forums/showthread.php?t=61591
http://www.polkaudio.com/forums/showthread.php?t=57084
http://www.polkaudio.com/forums/showthread.php?t=51533Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
If cost is an issue, buy a used one.
Looks like fun...but I'm currently in college (dorm) and away from home, so I doubt I'd be able to build that here.
But having a SVS in a dorm room would be nice
