RT F/X vs. R15 in RT1000p setup
ViperZ
ViperZ Posts: 2,046
edited January 2008 in Speakers
Hey all,
I am currently using R15's as my rears (with RT1000p and CS400 setup), mainly for home theater.
Would RT F/X be a big upgrade from R15s? Would these speakers match with RT1000p's?
Thanks!
:confused:
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
Post edited by ViperZ on
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2008
    anyone?
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • polrbehr
    polrbehr Posts: 2,852
    edited January 2008
    I think so.
    I went from R15 surrounds to FX500i, they made a huge difference, even though fronts stayed the same (R50s) for quite awhile after that. Not even close, to tell the truth. You can always keep the 15s as extra rears if you go with a 7.1 in the future.
