Polks and tubes?
alpha-7
alpha-7 Posts: 3
edited February 28 in Clubhouse Archives
I've been thinking of diving into the shallow end of the tube amp pool with a low cost tube amp such as the Zen or the very cheap Antique Sound Labs Wave-8 monoblocks ($99 each!). Was wondering if any Polk owners have experience running their speakers off of tube gear. I have several pairs of Polks, the best being RT1000s. At 90db, they should be effecient enough for reasonable sound levels, but i figured i'd best check for any first hand experiences.
thanks,
Ray
Post edited by RyanC_Masimo on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited September 2001
    I need links to these amps you speak of.....
    Interesting thought, as far as tubes go, my only experience is with horn-loaded speakers....(and guitar amps).
    Cheers,
    Russ
    If nothing else, glowing tubes and polks sure would look cool anyway....
  • wangotango68
    wangotango68 Posts: 1,056
    divertech .com is were you can find those amps. there in canada.
    scott:cool:
  • alpha-7
    alpha-7 Posts: 3
    Yes, divertech.com for the ASLs and Decware.com for the Zens. The Zen only puts out about 1-2 watts, but apparently this is enough to drive most reasonably efficient speakers to a good listening level (obviously not blasting with something like a Polk).
  • ghsueh
    ghsueh Posts: 1
    edited June 2002
    I'm using the ASL Wave 8 monoblocks with Polk RT35is. They are terrific. Imaging is solid, sound is warm and detailed. Most importantly, they make music fun. They play loud but the Polk's impedance curve probably causes them to clip at lower levels than the 90 db sensitivity would suggest. I haven't seen the curve for the RT35i, but if it's similar to the RT25i (published in Stereophile), there's a dip to 4 ohms.
  • RuSsMaN
    edited June 2002
    THAT holds the record for a resurrected post.....
    -R
