Increasing performance of my Bic-h100 sub
edited January 2008 in Speakers
After calibrating my Yamaha 1800 with cross over set at 60Hz and telling my receiver to output base on my front LSI15 AND SUB. I watched 310 to Uma on BluRay last night (btw, this move just rocks for 7.1 PCM, one of the best I have ever heard. I might need to buy this for reference material). But anyways, I noticed the base is not too deep and was wondering how I can increase the deepness of my sub? Should I manually increase the crossover? Biamp (not sure what that means.
Also, when I turned up my sub volume close a little bit over halfway, the receiver complained it was too loud. Why is it complaining and what are the effects if I dont lower the volume (base distortion?)
Any help appreciated.
Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
"The more time you spend researching here, the less money you will have" :D
Post edited by Gizmo99 on
Welcome!
    edited January 2008
    Try the sub in a few different locations in the room.
    edited January 2008
    i might be wrong on this but try seting the phase 180 deg off on the sub the bass from your front speakers might be canceling out your sub
    onkyo 805
    rti8 front
    csi3 center
    fxi3 surounds
    rti4 back surounds
    2 carver m1.0T fronts
    and subs
    5-marantz ma 500
    110" screen
    mits 1500hc
    2-psw1000
    edited January 2008
    I thought the same thing but I didnt notice too much difference when I toggle between the phases. Will try again tonight.
    The only way I could reallyfeel the base if I turn the volume a little bit more than mid way
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
    edited January 2008
    Gizmo99 wrote: »
    If you're turning the sub volume beyond the midway point, get a bigger, better sub because you're probably getting a ton of distortion.
    In the meantime, try increasing the sub's volume from within the receiver and decreasing the volume on the sub.
    "God grooves with tubes."
    edited January 2008
    I don't know if this really works or not ...
    move your chair and put the sub where you normally sit. Now, play something. Walk around the room and find where the bass sounds the loudest. Put the sub there, put your chair back, and listen from where you sit.
    edited January 2008
    Could it just be a weak LFE track?
    edited January 2008
    A sub with the LSi15's?
    I wouldnt do it. 3 subs in 3 different locations. Asking for a headache. Probably have phase issues that cant be fixed. Phase correct @60hz but wrong @ 30hz. Then you fix that and end up the opposite, phase ok @30hz but wrong @ 60hz. A common problem when dealing with more than 2 subs. Tweek it the best you can.
    Just my opinion.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
Welcome!
Welcome!
