RTi10 + Onkyo TX-SR705, to amp or not to amp?
Howdy,
I am just coming up to speed on this hobby.
I have
left,right: 2 RTi10's
center: CSi5
surround: 2 FXi3
back surround: CSi3
sub: DSW Pro 600
My receiver is an Onkyo TX-SR705.
I listen at moderate volume but like nice sound.
I have my receiver set to crossover the RTi10's to the sub at 50Hz to avoid
over taxing it.
My question:
Am I under powering the RTi10's with this receiver and set-up and would I hear much of a difference if I added an additional amplifier?
(Receiver specs below).
If not swell, but if so, can you recommend something which will do the job
but still be economical?
Power Output -
Front L/R 100 W + 100 W (8 ohms, 20 Hz20 kHz,
0.08%, 2 channels driven, FTC)
Center 100 W (8 ohms, 20 Hz20 kHz, 0.08%,
Surround L/R 100 W + 100 W (8 ohms, 20 Hz20 kHz,
Surround Back L/R 100 W + 100 W (8 ohms, 20 Hz20 kHz,
Dynamic Power 240 W (3 ohms, 1 ch)
210 W (4 ohms, 1 ch)
120 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.08% (Rated power)
I have
center: CSi5
surround: 2 FXi3
back surround: CSi3
sub: DSW Pro 600
over taxing it.
My question:
Power Output -
Post edited by polka on
Yes...
Amp away. Amp your Csi5 and Sub too. It does sound better.TV: Hitachi P42H401
DVD Player: Sony Playsation 3
XM Tuner: polkaudio XRt12 Reference Tuner *SOLD*
Console: Nintendo Wii
Cable: Tivo Series II DVR *SOLD*
Receiver: Onkyo 705
Amps: (3) Outlaw M200
Center: polkaudio CSi5 *SOLD*
Fronts: polkaudio RTi12s *SOLD*
Sides: polkaudio RT8s *SOLD*
Rears: polkaudio RT8s *SOLD*
Sub: Invisible
thanks for the append nodeuces. i just ordered RTI8s. I bought the CSi3 (open box price could not pass up) and I have a velodyne sub. I am reading all the threads about not having a pre-amp out since i have the onk605. am i totally screwed here? earlier i was looking around for my surrounds, but now I don't know if i have enough power for all of this. any advice? should i downplay my surrounds or am i already done with just my fronts?
Yes...
How about a little more guidance here.
How significant will the difference be (e.g., will the wife notice?)
And can someone recommend an economical but reasonable
amp choice?
Thanks. -
You can get more for your money if you buy a used amp from Audiogon. I always recommend at least 200wpc, and getting a 5-7 channel amp for all speakers. It is not cheap, but you only have to do it once.
Brands to look at are Parasound, Sunfire, Rotel, Adcom, Nad, B & K, Outlaw.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Start small. Amp Right and Left. Get the Outlaw Monoblock amps. Then get the center amp. Then the Sub amp.....then go from there.TV: Hitachi P42H401
Receiver: Onkyo 705
Sub: Invisible
I got a question...instead of making a new thread, since it falls under the same topic, figured I'd ask here...
Ok, i have the Onk 705 and well im getting my RTi8's supposively tomorrow....anyway, I know amping is usually a good idea, but how does it sound w/o an amp, i was planning on getting the speaker set up and then worrying about amping and whatever else....im really changing from my HTIB yamaha, I mean REALLY CHANGING! -
shimey013 ... let me know how your RTi8's go without "amping" when they come in tomorrow. what's your center by the way? I am kind of stuck since I have the Onk 605 and now scrambling on a new receiver now (no pre-am output).
Havent bought a center yet, im kinda piecing it together based upon my budget, i was looking at the CSi5 but im having a hard time finding it, i may drop the money on the Csi A6 or save some and pick up a CSi3...I havent make my decision...I have a couple weeks to make this decision since i can only get 1 speaker or paid per check
Right now im slowly tearing apart a Yamaha HTIB i bought like 5 yrs ago...so im replacing speakers as i can. -
Here's my setup:
Front: RTi10's
Center: CSi3
Surround: WAS RTi10's (replacing them with FXiA4's)
Sub: DSW Pro 600
Receiver: Onkyo 605B
Amping the sub and RTi10's would definately get me more sound, but for my appartment this receiver works great."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Welcome Shimey.
It is not required that you get separate amplification. We are simply letting people know that their systems will sound significantly better with separate amplification. But at least if you do decide you want more power, you already have the preouts in the receiver to do so!
So by all means get everything setup & calibrated & enjoy.I got a question...instead of making a new thread, since it falls under the same topic, figured I'd ask here...
Ok, i have the Onk 705 and well im getting my RTi8's supposively tomorrow....anyway, I know amping is usually a good idea, but how does it sound w/o an amp, i was planning on getting the speaker set up and then worrying about amping and whatever else....im really changing from my HTIB yamaha, I mean REALLY CHANGING!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I got my RTi8s today and connected them to my 705 and WoW, with the size of the room they are in amping isnt needed...nice clear sound, I really notice a difference..so if your going to buy the 705, connect them see if they give you what you want (everyones preferences differs) and then decided if you need an amp or not. I really dont think im going to amp mine, doesnt sound like i need too. -
Amps to some people are like speaker wire to others.
I will say adding an amp was the one thing I did to my system that my wife commented on. Not that I make a lot of changes to my system but I digress.
Keep in mind I had a PC Ultra sub before the amp so bass was not a problem. However after I added the amp and set the RTi-10s for large/full range we sat down with her brother to demo the opening scene of Master and Commander. The bass impact was noticeable more visceral with the amped RTi-10s. To which my wife said, “it feels just like a movie theater!”. Made me very happy.
I would recommend the B&K product line. Basically because it’s the only external amp I have had, I think it sounds great and they can be had used for reasonable money.
Edit to add, I think you will notice an improvement at moderate volume levels as well. And I think the dialog from my center is also easier to understand at lower volumes.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
The lower -3dB point of the RTi10s is 35Hz. If you have a capable sub that will hit 20Hz, I recommend making use of the 705's very flexible independant crossovers and setting them to 50Hz (as polka is). This gives you about 1/3 octave above the -3dB point for a transition to the sub, will free up headroom in the receiver's amp (and let the subwoofer's amp take over the duties), crosses things over low enough that directionality isn't a problem, and should make them generally sound better.
The Audyssey setup in the 705 will align phase between the mains and speakers (and EQs in the time domain to prevent phase shifting and cancellation), so crossing them over should give you a good result. The only problem is that Onkyo's implementation of Audyssey sets any speaker with good output below 80Hz to Full Range. Chris from Audyssey has said over at AVSForum that they wanted Onkyo to use 40Hz as the threshold for full range, but that 80Hz is what they went with. All things considered, the RTi10s are NOT full range speakers, nor should they be run as such if you don't absolutely have to, regardless of whether you're using external amplification.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
