Upgrade or Update?????
Braddles
Braddles Posts: 228
edited January 2008 in Vintage Speakers
I asked about updating my monitor 12s in another forum and seems most think i should update what ive got.
I bought the monitor 12s new 17 years ago and they are still in as new cond.
Ive read about the RDO replacement tweeters. So their easy enough.
The crossover upgades, are they somthing you can buy as a complete item or do i need someone to build me some?
Do you suggest adding 5 way binding posts at the same time?
If i were to update which current model would you suggest would be a step up?
Amp - Jas Audio Bravo 3.2 set
Power Cord - Tunami GPX
CDP - Marantz cd6002 - Audio gd Ref 5 Dac
Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed.
Post edited by Braddles on
  • avguytx
    avguytx Posts: 1,628
    edited January 2008
    Me personally, I would swap the tweeters for the newer RD0's that your particular model takes. As far as the crossovers, there isn't something already done to just replace them with so if you're handy with a soldering iron, you are good to go. There are many threads in here about cap and resistor replacements and what types all of us use. There will be differing opinions on caps and it will boil down to cost for most versus the end benefits. But it is more than worthwhile as you would be hard pressed to find a better speaker out there than what you've got. Those are some beauties!
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2008
    Very nice system! Not really any reason to upgrade unless you've just got the itch too, or there is a WAF reason to try to move to smaller speakers. Those monitors are still very good sounding speakers. You would probably need to go to the Polk LSi series to make any significant improvement. Others might argue that even then it's not really an improvement. Welcome to the forum. I've spent some time in your country, love to go back some day.
    DKG999
  • cubdog
    cubdog Posts: 835
    edited January 2008
    My 12s are in about the same condition as your. FWIW I hear nothing to indicate they need upgrading. The tweeter doesn't bother me although my high freq hearing is pretty bad.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • Ricardo
    Ricardo Posts: 10,634
    edited January 2008
    Beautiful set up you have. I love that TV stand...if I could call it like that.
    You could upgrade tweeters, though the change won't be as pronounced with yours (the SL2000's show the biggest improvement, and it looks like yours have the SL3000's).
    Upgrading the crossovers with higher quality components will also give you some improvement. Lots of threads on that and it is not so difficult.
    SOPA
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Dude they are beautiful, and compliment your house very well. Update with a few simple mods. If you wanted to ship the XO's here I would be more than happy to do them. You could probably find a local electronics shop to sway caps, and resistor to bring them into better than new standards.
    Ben
