Question about surrounds
ryanjoachim
ryanjoachim Posts: 2,046
edited January 2008 in Speakers
I have:
2 RTi10's - Front
CSi3 - Center
DSW Pro 600 - Sub
Now I need to figure out some surrounds to go with...With how my setup is, I think dipole/bipole is where I need to go.
Are the Polk FXi series a good match for my setup? Or has anyone had experience with surrounds of equal quality that may be from a different manufacturer?
P.S. I NEED to have speaker stands for the surrounds...not sure where to get those from.
Thanks a lot for all the help
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • phipiper10
    phipiper10 Posts: 961
    edited January 2008
    See here -
    http://www.polkaudio.com/homeaudio/products/individual/bookshelf/?helpid=44
    Left nav. describes differences in the speaker series
    Something called the internet can help you find stands- I'll go a step further - a great site called....www.google.com - but keep it on the DL. ;)
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • trubluluc
    trubluluc Posts: 2,067
    edited January 2008
    Welcome!
    1. The surround you mention should work fine.
    It's not as important for your surrounds to match the timber of your front and center speakers. You would notice a sound sweep going from one main speaker...across the center to the other main much more significantly than a sweep going from main to rear surround.
    2. Go to: racksandstands. com they should have something you can use, but if possible, to save space and get the speakers higher therefore more background like, mount to the rear wall.
    -Luc
