CSi5 or RTi A6 ? (to match RTi8's)
Are these really the same speaker?
I have a CSi3 new in a box (unopened at this point), and am thinking I should just sell it and buy a CSi5 (if I can find one) or the RTi A6 if it is comparable. I bought RTI8's for my fronts, and everyone has me a tad concerned that the CSi5 is THAT much better ... and if so, I have to have it
Opinions?
Anyone seen 5's (black) anywhere? (would even consider mint, used.)
Or, RTi A6 for a good deal? (I found a black one for 349.99 which I think is a good deal.
I'm in Canada if anyone wants a good deal on a CSi3 ! (email me at java@nbnet.nb.ca - located in Quispamsis, N.B.)
Thanks everyone as always !
David
Opinions?
David
Post edited by kosaic on
IMHO the 5 is just soooooo much better. If you can find one then get it.
David
Where?Rti8
CsiA6
Rti4
PSW505
Yamaha 6050 -
I have the opportunity to buy the CSi A6 today for a great price.
Should I hold out for a CSi5, or is the A6 just as good? (is it the replacement for the 5 ? )
This is to go with a pair of RTi8's...
Please let me know your thoughts before I pull the trigger.
Thanks -
Anyone?
I dont want to waste money on a CSI A6 if it isnt the same speaker as a CSi5 (more or less)
Thanks again,
David -
Anyone?
Thanks again,
David
It is basically the same speaker. Drivers and tweeter are the same as the Csi5. Only difference is the cabinet. There doesn't seem to be a lot of reviews yet on the a6 but I'm sure it will sound very similar.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's -
andrew_mac wrote: »It is basically the same speaker. Drivers and tweeter are the same as the Csi5. Only difference is the cabinet. There doesn't seem to be a lot of reviews yet on the a6 but I'm sure it will sound very similar.
That's what I thought...just a minor facelift..Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
