Adcom GFA-555 & GFP-555
mhartman29
mhartman29 Posts: 257
edited January 2008 in Electronics
I saw an ad for what seems like an inexpensive combination of these items. I tried to read up on them a little here and google, but didn't find too much.
What do you all think of this pre & amp combo? Is it worth buying for stereo applications?
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    The Pre is harsh(not terrible, but grainy) It is very punchy, has a great tuner, and a phono input. The amp Kicks butt. You can get $100 for the Pre all day long if you decide not to keep the pre. A lot depends on your speakers to. What are you planning on driving with this?
    Ben
  • vonnie123
    vonnie123 Posts: 326
    edited January 2008
    The preamp is a good device that has tuner, aux, and phono inputs. I sold mine a couple of years ago for around $125 The GFA 555 amp is a great machine, although I had to change out the RCA input jacks due to a mechanical failure. I bought it new in 1988 and it has served me well. A couple of cooling fans on top of the amp case would benefit the device.
  • engtaz
    engtaz Posts: 7,669
    edited January 2008
    Amp is great but prefer other pre's.
    engtaz
    engtaz
  • George Grand
    George Grand Posts: 12,256
    edited January 2008
    That amp's grainy top end seems like it would be a perfect match to the grainy preamp. I never had the pre, but that amp? Grain city.
    heiney9 Posts: 25,534
    edited January 2008
    I've had several Adcom's never found them grainy. Different strokes for left handed people. At that price you could easily recoup your funds if it turned out you didn't like either or both. I say go for it and see for yourself.
    EDIT: oops you didn't post a price. If it's $400 or less for both that's a decent price. Not a steal at $400 but decent. IMO, the only Adcom pre that is any good is the GFP-750. The others are very very mediocre.
  • Wesley Snipes
    Wesley Snipes Posts: 26
    edited January 2008
    I just picked up the GFA 555 (rack mount) on ebay for $250.. I haven't yet recieved it but pretty good deal? Is it rated 200 wpc RMS? or is that peak? It's hard to find info on this amp.
    edited January 2008
    Here's some info. 200W x2 @ 8 ohms 325W x2 @ 4 ohms and that is a conservative rating as many tested higher than the factory specs.
    http://www.stereophile.com/amplificationreviews/678/
    edited January 2008
    1989 Measurements
    The Adcom GFA-555 was a powerhouse. Output at clipping was 231.7W into 8 ohms (23.6dBW), increasing to 331.9W into 4 ohms (22.2dBW). Like the PS Audio 200C, however, the GFA-555 blew output fuses when asked to drive a 2 ohm load to high levels. Again, the power supply seems much more robust than the output stages. Incidentally, I have owned a GFA-555 for about three years and never had a fuse blow during normal (music-listening) use.
    Frequency response was very flat over the band (fig.1), with a slight (0.2dB) rolloff at 20Hz and 20kHz. There was about a 0.1dB level difference between channels. Output impedance was extremely low at 0.05 ohm over most of the band, rising to 0.07 ohm at 20kHz. THD was constant across the audible band at about 0.04% with 5W output into 8 ohms.
  • mhartman29
    edited January 2008
    Thanks for all the info guys!!!
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • Lowell_M
    Lowell_M Posts: 1,660
    edited January 2008
    heiney9 wrote: »
    I'm left handed and wouldn't replace my GFA-555 for anything anywhere close the $300's I paid for it. I've never experienced any grainyness either.
    Buy the combo, sell the pre.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • mhartman29
    edited January 2008
    Unfortunately, I lost out on the item. I emailed the guy, but he had already sold it! Oh well, I know to keep my eye out for that amp. Thanks again for all the info!
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
