a/v receivers
anybody have a marantz receiver if so how do you like it with your polks
because i have a sr7002 marantz and can not say enough good things
about it
about it
Post edited by caboa on
Thanks for sharing. Welcome to Club Polk.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I have the sr7002 driving RTi8. It's really good. Before I have the marantz, i had an old denon wiht 80W/channel, and then i bought the Denon AVR987 (110W/channel). I wasn't happy with it, so I searched on the web and found martanz. It's well worth the upgrade! I appreciate the RTi8 much better and happy with the bass. There was no bass from my old Denon!anybody have a marantz receiver if so how do you like it with your polks
about it -
I have an 8001 and couldnt be happier. I controls two of my rooms, both audio and video in each room. It seamlessly switches from multiple sources (although took a bit of tweaking in the beginning). I am super happy with Marantz.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
