Freeze & Water
dice727
dice727 Posts: 22
edited January 2008 in Car Audio & Electronics
so i was looking at my friends system today, and i noticed that he had almost a pool of water on his amp. he had no idea where it came from but i think there was frost on it, and it must of melted. we live in wisconsin, so this might happen often. i am just wondering if there are any tricks that i can use to prevent this from happening. i am sure that that cannot be good for the amp...any ideas
Post edited by dice727 on
  • 66chevyIISS
    66chevyIISS Posts: 857
    edited January 2008
    Idea, try starting with bringing it INSIDE to listen to :p
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • dice727
    dice727 Posts: 22
    edited January 2008
    it powers the subs in my CAR, so yeah
  • Kinetic
    Kinetic Posts: 437
    edited January 2008
    here in mexico theres a place called toluca, and its the only place with snow arround here.
    people from there, buy a cigarrette, and take out the tobacco.
    they clean their windsields with the tobacco, and the oil of the tobacco prevents the windshield to freeze.
    i dont know if its safe to use it on your amp, but thats an idea.
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • dice727
    dice727 Posts: 22
    edited January 2008
    like you just run it on the window or what, cuase that sounds interesting
  • 66chevyIISS
    edited January 2008
    lol, I thought that was kind of strange. I was looking at "new posts" and didn't pay attention that this was in the "Car audio" section dur!
    My showcase link:
    Media Room pics
  • Kinetic
    Kinetic Posts: 437
    edited January 2008
    dice727 wrote: »
    yeah you put it like soap, and the tobacco oil will atach to the windshield surface.
    Z
    Polk Audio SR 6500
    G35
  • schwarcw
    schwarcw Posts: 7,360
    edited January 2008
    Kinetic wrote: »
    Sounds good, but if you're a non smoker, it probably smells like ****.:(
    Carl
  • DemonAstroth
    DemonAstroth Posts: 131
    edited January 2008
    There's RainX, which is supposed to do the same for the windows.
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Kinetic wrote: »
    The most awesome response I've ever heard. If you are worried about the smell, just pipe tobacco. It smells good.
  • michael_w
    michael_w Posts: 2,813
    edited January 2008
    I wouldn't really recommend rainx or smearing it with tobacco.... to me that's like using armor all on your speakers. You may just have a problem with sealing your trunk that needs to be fixed so that moisture in the air cannot get in as easily, although it may be tough. Check it after your car has warmed up and see how much condensation is there.
