Just got Polk Audio RTi8's
Rike255
Rike255 Posts: 131
edited January 2008 in Speakers
They sound much better then what I had before. But I find the lower range to be lacking. I'm wondering if it's my receiver.
I own a crappy Sony STR-K900. Is this receiver not good enough to power the RTi8's well?
I'm just wondering if the sound will improve greatly when I finally buy a new receiver.
Thanks in advance.
Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim
Post edited by Rike255 on
  • Willow
    Willow Posts: 11,064
    edited January 2008
    congrats, and yes buying a new receiver with pre out and add external amps you will notice a big diff. My 200wpc monoblocks prove it.
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    IMHO a subwoofer would be what you need. The amps are a great help but if your looking for lows you'll need a sub.
  • wizzy
    wizzy Posts: 867
    edited January 2008
    Check out the Velodyne Digital Drive 1812 Signature Edition
    This would give you a little extra oomph in the low end
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2008
    my 8's go deeper than i thought possible. i listen to music in direct/ 2ch stereo mode. but if i wanna listen to some bass-heavy music, i set the soundfield to include my sub. rap makes me wanna bring the roof down!
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • mhartman29
    mhartman29 Posts: 257
    edited January 2008
    Rap makes me want to bring down your roof, too! :)
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
    Signal Analog II ICs
    Signal Ultra speaker cables
  • Rike255
    Rike255 Posts: 131
    edited January 2008
    It must be my receiver then because they don't sound deep at all.
    Onkyo TX-SR805
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    Does your receiver have a bass adjustment? I must agree w/Bizill though,they do go deeper than I expected. But, a properly blended sub makes a ton of difference.
  • Rike255
    Rike255 Posts: 131
    edited January 2008
    Ya it does, I tried playing with that it didn't really help much. I think it's just because the receiver is so low quality. It's one of those "home theaters in a box" type deals I got a long time ago.
    Onkyo TX-SR805
