New digital 5.1 Pre/pro suggestions
univera
univera Posts: 848
edited January 2008 in Electronics
I'm considering going in the direction of a seperate HT pre-amp to replace my NAD as I believe it may be FUBAR'ed and I don't necessarily want to replace my AVR with a new one that will at some point become obsolete. I am very happy with the NAD performance and sound, particuarly musicality.
Any suggestions on options for a great, dedicated, 5.1 pre/pro at least on par with NAD and worthy of mating with my Anthem amps? I am open to new or used in the $1000-1500 or less range and would like the ability to update as well. Not sure where my budget might fall, but Panamax should cover my claim for replacement of my T-773, which should be at least $1,000. Thx.
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
Post edited by univera on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2008
    I would look for a Rotel RSP-1066 or RSP-1068. I believe Mantis is selling his 1068 in the flea market.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2008
    Welcome back Univera, long time no see.
    What features do you want the prepro to have?
  • univera
    univera Posts: 848
    edited January 2008
    Thanks, glad to be back. I'm looking for basic 5.1 surround. I'm not up on the latest needs in pre/pros. My NAD AVR is not HDMI compatible, but I haven't found that to be a big deal. I plan on using my Anthem pre-amp with pass thru for 2 channel duty, so 2 channel quality isn't my main objective or need. I'd like a future-proof unit (in theory, anyhow.) My room is 3 sided with glass doors behind the couch and hardwood floors and no drapes, just blinds, so I could use something that allows for contouring and honing in the sound.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    http://www.outlawaudio.com/products/990.html
    https://www.outlawaudio.com/mofcart/bstock.html
    OutLaw 990 B stock $800.
    No HDMI, but has phono input, balanced outs, DVI ins, and outs(you can use a DVI to HDMI adapter).
    5 year warranty. Great CS.
    Ben
