SQL Guru's!
jdhdiggs
Ok, long shot I know. I usually do this formatting crap in access then dump it to sql for processing but in this case the dB is WAY too big. What I need is a SQL query for converting: 20060310 into 03/10/2006
SELECT
(Left(Right(W2S_FINAL1.[Del_creation_Dt],4),2) & "/" & Right(W2S_FINAL1.[Del_creation_Dt],2) & "/" & Left(W2S_FINAL1.[Del_creation_Dt],4)) AS OrderDate
FROM W2S_FINAL1
Keeps erroring out:
Server: Msg 207, Level 16, State 3, Line 1
Invalid column name '/'.
Server: Msg 207, Level 16, State 1, Line 1
I know I'm missing something massively stupid., :mad:
If you want to go straight to SQL date, that works as well....
SELECT
FROM W2S_FINAL1
Keeps erroring out:
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
Post edited by jdhdiggs on
Ok if I understand what you're doing... Open the file up for html editor and remove any database name stuff should be like 2 lines on the first 10 lines or so. The database doesn't like to be named.
Hope that's are I'm missed what you're needed.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
No, this is purely for sql, no html.
Basically, it's erroring out on trying to place the / charector into the srting.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
What SQL database are you using? Microsoft SQL Server? What is the field type that contains the data you're trying to manipulate?Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
It could be several things, but have you tried changing the ampersand to a plus? Access uses & while most SQL databases use +Speakers: Polk LSi15
Sql server varchar field type. Haven't tried the +'s yet. Thanks!
edit: It's running but has to chew through 50MM records so it may be a while....There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
I don't reconize the syntax of your statement so I am not exactly sure which database you are using. I am assuming the date value is stored in the table as a character string as it looks like you are using substring commands.
Based on the error message, are strings delimited by double quotes? Is the / character a special character? Does it need to be prefixed by another character in order to be interpreted as a character in the statement?
I created the following in an Oracle10i environment:
create table temp
char_date VARCHAR2(8) null
insert into temp (char_date) values ('20060310');
insert into temp (char_date) values ('20080124');
SELECT TO_CHAR(TO_DATE(char_date,'YYYYMMDD'),'MM/DD/YYYY') AS ORDER_DATE
FROM TEMPAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
create table temp
FROM TEMP
That looks a ton better. This is in a sql server environment so I'm not 100% that your syntax will work but I'll try it when I get a chance. It's still running tcrossma's versionThere is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
SQL Server
SELECT CONVERT(CHAR(10),getdate(),101)
Oracle
SELECT TO_CHAR(sysdate,'MM/DD/YYYY') FROM DUAL -
I know but an web page editor.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I was using Query analyzer if that helps. Looks like the TCMA advice works but it's still running....There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
You could use SELECT TOP xx to test it 1st.
