wierd noise
Kinetic
guys i recently try to bridge the PDX-4.100
so instead of having 4x100, now i have 2x200.
so i adjust the gain to have 100 RMS per channel, but without distorsion.
i bridged as i read in crutchfield:
http://www.crutchfield.com/App/Product/Item/Main.aspx?i=500PDX4150&search=4.150&tp=115&tab=review
So I put the positives on the odd numbered channels 1 and 3 with their respective negatives on the even numbered channels 2 and 4.
sounds a lot better, but there is a little wierd noise, when i turn on the HU, its like interference, or like the old computer fax-modems.
if I turn the volume up to 15 the noise goes away and the music starts, after that i can listen the HU at any volume level, the noise only appears, when i just turn the HU on.
I already check:
the IC on the HU
the ground on the AMP
try with different GAINS
the speakers conections
the RCA (each one)
what else can it be?
I already check:
the IC on the HU
the RCA (each one)
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
Hmmm... could it be electrical interference? Are you running the RCA cables and power wire on opposite sides of the car?
Does the noise stay constant or go up with volume?
yes I have the rcas and speakers wires on the right side
the power wires on the left sideZ
Polk Audio SR 6500
G35
KnuKonceptz MKS Kable -
its constant, and when i turn up the volume up to 15 (aprox) the noise goes away, and then i can have the volume from 0 to 35 without noise.
when the noise is on, theres no music.
i will try to put a videoZ
Polk Audio SR 6500
G35
Really!
Let me get this straight. You turn the volume down when you turn the car off. Now when you get back in and start it up, constant noise. The noise dissapears once the volume goes above 15, even if you back it down after.
I would look for alternator noise, but I can't understand why it would disappear.
One more question, does reving the engine change the noise at all? -
Really!
Yes thats rightI would look for alternator noise, but I can't understand why it would disappear.
yeah me tooOne more question, does reving the engine change the noise at all?
no, when i rev it, sounds the sameZ
Polk Audio SR 6500
G35
Check the wiring on the amp. Loosen and retighten if possible.
Next step would be to swap the amp temporarily. If that works, mess with the amp. You could try hooking it up with a cd player and small battery in house. -
cool i will do that
thanks a lotZ
Polk Audio SR 6500
G35
a guy on the caraudio forum told me that this is a normal mistake on all the PDX amps when you bridge them.
and theres nothing i can do.
what do you think?Z
Polk Audio SR 6500
G35
My guess is that there is some kind if biasing issue with the amp. This is not something you should even consider fixing.
Depending on the type of circuit used, and how it bridges, he could be right. I personally doubt a company would advertise the amp as bridgeable without having successfully done it themselves. -
thats what i thought about a brand name as Alpine, but i try to talk to Alpine of Mexico and they are so incompetent, the dont have any information.Z
Polk Audio SR 6500
G35
