audio delay in receivers
CAvolleyballguy
CAvolleyballguy Posts: 156
edited January 2008 in Electronics
Hello,
I notice i get some serious delay some of the time. I know some cable channels cause this more than others. But I was curious how much of this is caused by my receiver.
Even on HDMI out of the blu ray there is a delay between the TV audio and the HT speakers. It is slight, sounds like an echo..when I turn off the TV sound the lip synch is un noticeable, but I know it is slight...was just curious if better receivers resolve this better. I know newer tvs have a lip synch function if using HDMI, but my current TV does not.
My receiver right now is a onkyo705
Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
Post edited by CAvolleyballguy on
  • hockeyboy
    hockeyboy Posts: 1,428
    edited January 2008
    If you hook your cable box audio through your receiver first, and not directly to the tv that will probably fix it.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • CAvolleyballguy
    edited January 2008
    long story short, my hdmi on my tv broke...so I have component video and audio going from cable and dvd player into TV. I have hdmi 1.3 from cable and dvd to receiver. I can play tv with sound without the HT. but when I want HT I have full 1.3hdmi audio..
