Polk on E-bay!
zingo
Well Polk County I guess, but cool looking place.
http://cgi.ebay.com/Polk-County-N-C-home-with-acreage_W0QQitemZ190171553376QQihZ009QQcategoryZ12605QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
What I think is sad, is that living in Seattle and saving up for a place, $325K gets you a condo. For that place where I live, a couple million at least.
Post edited by zingo on
I didn't even no ebay had a realestate section.:o
Inexpensive housing ... definitely one huge advantage of living in the midwest! Although I guess NC is not exactly midwest ... but you get my point. Wonder if there is a Polk county in KS?nikolas812 wrote: »I didn't even no ebay had a realestate section.:o
Well, you should check out eBay more often so that you can know more about it ...My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
Did you catch this from the ad?Double wide upgraded with wood siding, two decks, covered porches,new windows, inground pool and mutli-car detached garage.
It's a trailer with wood siding. Way overpriced for my area, trailers, even on ten acres will be lucky to get $40,000. -
Well no matter, 10 acres would be 3/4 of the price here. Stupid housing prices. Although, that rate cut by the fed should help.
