Speaker Rubber Feet
I've installed the rubber feet that comes with the FXi-5 and was wondering if anyone hear knows how I can remove without damaging the speaker's finish?
Post edited by avphile on
Stick on? Warm them a little bit with a hair dryer, should pop right off.
WilliamM2,
I am assuming that the FXi-5 cabinet is held together by glue and screws. Do I run the risk of messing up the glue in the seams or the glue that is holding the laminate/veneer in place?
