lsi 25's
edited January 2008 in The Clubhouse
I am interested in your opinions.
I currently own 3 LSi 25's, I purchased them at a great price and could not pass them up. I am trying to decide on whether to get a fourth and use a true center speaker or use the third lsi25 as a center and purchase lsi 15's for the rears in a 5.1 set-up.
Is this overkill? should I split these up and purchse lsi 9's instead for the rears? Any suggestions?
Post edited by jonlereux on
Welcome!
    edited January 2008
    Is it overkill? Probably. Should you do it? Hell yeah.
    I say run dual 25s as a center while you're at it.
    edited January 2008
    Overkill? No, I'd think it would sound very good!
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    edited January 2008
    Shizelbs wrote: »
    Bad idea. You'll get major cancellations if you do this. I know you were probably joking but I feel it's my duty to point this out. :D
    edited January 2008
    Get the fourth.....and a lsi center and your good to go.Just for **** and giggles,what are you powering all this with?
    edited January 2008
    Set them on fire.
    edited January 2008
    Demiurge wrote: »
    Set them on fire.
    Somebody is grumpy tonight.........wouldn't have anything to do with the piss poor performance from the Pack would it?
    edited January 2008
    I am currently awaiting an outlaw amp and preamp. 990/7500 . Rated @ 300WPC into 4 ohms X 5 channels.
    My concern is with the Lsi's overpowering the center channel. Any thoughts?
    I would actually prefer this setup over using a 25 for a center, but I have heard that there are soundtracks that actually go below the capabilities of the center without a sub.
    Any thoughts are apreciated
    edited January 2008
    Thanks for the feedback, I have found a fourth LSI25 and will be using them as my four corners and will purchase an LSIc for the center. I will be running 5.1. Does anyone run 7.1 here? Can you notice a significant difference between the 2 formats?
    My wife is gonna murder me if I keep buying electronics!!
    edited January 2008
    Found mine @ Frys. I do not know if Polk is discontinuing the Cherry, but I bought the last three they had. The black was not discounted at all
    Only problem is that they do not ship to other stores so get them while you can
    edited January 2008
    officially, the Dolby digital codec supports five full range channels
    (including the center) of 20HZ to 20KHZ, I'm almost sure DTS also support a full range center channel,
    but I doubt many movies have been coded in a way that would cause the 25's 10" active woofer
    to so much as break a sweat.
    that aside if placement is not an issue for you, then you're good to go.
    "If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'"
Welcome!
Welcome!
