amps
Systems
Systems Posts: 14,872
edited September 2001 in Car Audio & Electronics
for my 2 mm120's, which will be put in a bandpass box, which amps should i consider?
also, i have a pair of momo 6.5's component set in the front and some infinity kappa 6x9's in the back, which amps would you recommend i check out for them
thanks
Testing
Testing
Testing
