Rti10 amp help for a noob
Hello
I am new to home theatre and have read the rti10 has allot more bass when hooked to a receiver and an amp (they call this bi-amp correct?) My setup is as follows
Avr-645 (75 watts per channel)
rti10
csi5
rti6
How much bass would an amp add to the rti10?
What kind of amp can you recommend new for around $1000?
Would the onkyo A-9555 be good for my purposes?
I am using 16 gauge speaker wire in short length would I benefit from 14 gauge or bigger?
Lastly my receiver is connected to a surge protector does this limit the power to the receiver? Should I run it straight to the wall? Any way to tell if you have clean power?
Thanks for your help any feedback is greatly appreciated
Regards,
Steve
rti10
csi5
rti6
Regards,
Steve
Post edited by StevenFo2 on
First off, welcome to the forum.StevenFo2 wrote:Hello,I am new to home theater and have read the rti10 has allot more bass when hooked to a receiver and an amp (they call this bi-amp correct?)StevenFo2 wrote:How much bass would an amp add to the rti10?StevenFo2 wrote:I am using 16 gauge speaker wire in short length would I benefit from 14 gauge or bigger?StevenFo2 wrote:Lastly my receiver is connected to a surge protector does this limit the power to the receiver?StevenFo2 wrote:Should I run it straight to the wall?StevenFo2 wrote:Any way to tell if you have clean power?
Again, welcome to the forum.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
TrippLite makes some fairly high quality, low priced surge protectors
Like this HT10DBS at Amazon ... yes, it does have EMI/RFI filters -
Hello
Thanks for the responses, I think I will focus on getting a good amp then work on the small details. So what amp is a good match for the rti10, I like the warm sounds from my avr-645 so what would match welll with it?
Will $1000 get me an amp to drive the 7inch 4 subs?
Thanks for your help -
I suggest the B&K product line for your speakers, I love how mine sounds. And yes 1K will buy you enough juice to get all the RTi-10s can offer. You will be surprised how much bass you can get out of that speaker.
I bought my amp used and if that is something your OK with take a look on Audiogon or Ebay. Think high current for this application and with the budget you have a 200 watt per channel should be your target (Cfrizz will be so proud of me )AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K
