How to extend boards?
Serendipity
Serendipity Posts: 6,975
edited January 2008 in DIY, Mods & Tweaks
Hi,
I've been trying to fix this projector outlined in this thread: http://www.polkaudio.com/forums/showthread.php?t=61305, but I have one question for you DIY'ers on electronics testing and repair.
I was wondering if anyone here knew how to extend PCBs in electronics so that they can be removed (and tested) with the projector running, so that they can be easily accessed. Because once the cover is open there are a few things that must be disconnected so the projector can't run while open.
In this case, I would need to extend boards from their original locations to make them more accessible for testing; what's the best way to do that?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
    treitz3 Posts: 20,275
    edited January 2008
    What we used to do is grab the female connectors from the parts bin [or order it x2] and install the desired length to both. There is a specific tool for this task and I'll be damned if I can remember the name of it.
    You might get lucky and be able to order one pre-built straight from an electronics supplier, keeping in mind the the color codes will not be the same.
  • Serendipity
    edited January 2008
    treitz3 wrote: »
    I tried and couldn't find anything that matches the Sony boards in that projector. So it makes it VERY difficult to troubleshoot with the projector running, as the boards are impossible to access without sliding them out or removing parts in the way.
