Kenwood Excelon?
BBBaja
BBBaja Posts: 5
edited January 2008 in Car Audio & Electronics
Anyone know anything about these amps - looking at it to power 2 MM2104 amp is rated @ 600x1 2ohms
Post edited by BBBaja on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited January 2008
    they are solid amps..... what would u like to know? i installed one into my friends ford ranger for 1 10".... not as solid as some other amps ive touched... but i would recommend one.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • BBBaja
    BBBaja Posts: 5
    edited January 2008
    Just mainly wanted to know about the quality as far as SQ and ability to play for long periods w/o overheating - it will be in a boat. THANKS
  • BBBaja
    BBBaja Posts: 5
    edited January 2008
    The amp is coming from Crutchfield - $299.00 - I wanted a good quality amp - If it is not going to fit the bill then I would return it and would be open to suggestions for a different amp in about the same cost range.
