Newbie Question: What RCA cable to buy for Receiver -> AMP
Gizmo99
Gizmo99 Posts: 169
edited January 2008 in Speakers
Sorry guys, all this Audio / Video stuff is new to me.
The back of my receiver:
http://www.yamaha.com/yec/products/productdetail.html?CNTID=558291&CTID=5000300&RLTID=1504&DETYP=RELATION#
The back of the Adcom Amp
http://pic6.audiogon.com/i/c/f/1200105533.jpg
Someone recommended these:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2864&seq=1&format=2
But the Adcom only takes ONE input. So what cable do I need to buy?
again, sorry for this newbie question :)
Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
"The more time you spend researching here, the less money you will have" :D
Post edited by Gizmo99 on
  • george daniel
    george daniel Posts: 12,096
    edited January 2008
    I don't understand,, the adcom has three inputs,,does it nor,,I'm assuming L,R, and csnter..so if you go 2 ch out on the receiver,one would go to the right and one to the left. And one one go th the center,if you have the output on the receiver for it.Good luck, and I;m not sure that your question was answered.
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    Fixiing link to back of the yamaha:
    http://www.yamaha.com/yamahavgn/Images/YEC/AV_Receivers/Views/PV_rxv1800bl_rear.jpg
    I understand what you are saying george, I just need the type of wire that go from Yellow/White on yamaha -> one input on adcom
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
  • george daniel
    edited January 2008
    would a "y" from the yammie to adcom(rca) do it?
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2008
    That should help. Use an RCA cable from the PREOUT section labeled CENTER, FRONT L(white), FRONT R(red) to the 3 channels on your adcom. There is no need for yellow video cables, no need for Y adapters, plain old RCA cables will do the trick. Problem solved.
    I hope that picture is clear enough. :D
  • Willow
    Willow Posts: 11,233
    edited January 2008
    Nice BL, couldn't be more clear.
    tonyb Posts: 33,072
    edited January 2008
    BL is not very good at explaining things,is he?:p:)
  • wizzy
    wizzy Posts: 867
    edited January 2008
    I dunno man. I had two white wires connecting L and R from a preamp to amp, and I SWEAR when I switched the R wire out with a Red one to match the color of the jack it sound soooo much better.
    You know, the white cables have the copper molecule's electrons aligned to the left, and the red ones have them aligned to the right. Totally opened up the soundstage!
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    Crap, I am totally blind hahahhaha.
    TGIF.. its been a long week
    tHanks..
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
