Basic starter questions????
Polkemon
Polkemon Posts: 144
Let me start with I am a huge POLK Fan with all my work trucks running the sr6500's. Now I am dealing with a question about Home speakers. I am debating on the RTi8 or the Monitor60 set for the front in a surround sound set up.I was wanting to go with the csi3 center unless you have a better choice. I am also not sure what sub to go with since I am mainly going to be using it for music and I would want the tightest hardest bass possible. I want a bass that attacks not just shakes but I would want it to sound good on movies I currently have the Klipsch sub-10 and it is way to boomy when playing music. Please let me know the best choices for my center, front & Sub. Do you have a sugestions on receiver brand? I am currently running a cheap 5.1 110watt per channel Yamaha.
NEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel
Post edited by Polkemon on
  • Willow
    Willow Posts: 11,334
    edited January 2008
    Out of those 2 choices, the rti8. But then lots of people say the 8s rtis are bright for music. I thought so as well untill I spent lots of $ on different gear and no longer find them very bright. As far as subs go see my post in your other thread.
  • mojo_13
    mojo_13 Posts: 22
    edited January 2008
    I have never heard the monitor 60's but I have heard the rti8's and they sound very nice especially for the price you can get them for at Fry's right now. As far as subwoofer goes what kind of budget do you have?
  • Polkemon
    Polkemon Posts: 144
    edited January 2008
    Not worried about the budget just want a good sounding unit.
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited January 2008
    I'd go RTi's.....Especially at the prices they are going for now. As far as a sub goes, I loved my Sunfire Super Junior for music, but it was a little rough to get it set up right, that little **** has a whole lot of power behind it...If budget is not an issue, I would go on the hunt for a Sunfire ultimate receiver I or II, they are basically their Theater Grand III processor with a 200X5 watt@8OHMs amp built in.
