Amp advice
brittle
brittle Posts: 37
edited February 2008 in Electronics
I have a Denon AVR3000 (110 watts @ 8 ohms) with preamp outs, should I buy a 2 channel amp to drive my LSi15's or blow the budget on a new reciever? I listen to 50/50 music/HT. I'd love a new receiver but would rather not spend $1,000+ right now. I would be quite happy with a used 2 channel if it does the job. Switching/upconverting is not that big a deal as my t.v. upconverts already.
Brittle
Pioneer VSX 94TXH AVR
Polk LSi-15 front
Polk LSi-15 rear
Polk PSW1000 sub
Polk LSiC center
Samsung HL67A750 DLP
Sony PS3
Post edited by brittle on
  • vonnie123
    vonnie123 Posts: 326
    edited January 2008
    I'd buy the amp if you are happy with the control functions of your AVR. You can pick up a nice Adcom 5500 2 channel Amp refurbished with warranty for about $850 from onecall. If you like other brands they can be had at around a similar price, some new, some used.
  • hockeyboy
    hockeyboy Posts: 1,428
    edited January 2008
    First I would try the Denon to see how it drives my speaks. I am not sure if that Denon is rated at 4 ohms but if so you will get a measurable push on amps with less impedence and it might drive the 15's just fine. You may also be able to bi-amp that amp but again I am not familiar with your Denon.
    I personally would never buy a two channel amp since it takes up rack space. I like the flexibility of at least 5 channels (so I can drive passive sub (s) if I want). IMO the value per watt of a 5 or 7 channel is better than a 2 channel amp. Save on the upgradeitus but thats just me.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2008
    Welcome to Club Polk.
    HockeyBoy has given good advice. If you have a HT setup go for a 5-7 channel 200wpc @8ohms amp on Audiogon. It will cost more money but you will be all set for years. Amps to look at are Sunfire, Rotel, Outlaw, B & K, Adcom, Parasound.
    You have great speakers, but the Denon can't handle them too well since it is not designed to handle 4ohms loads.
  • engtaz
    engtaz Posts: 7,675
    edited January 2008
    brittle wrote: »
    I would add a amp for front L & R and center.
    Good luck,
    engtaz
    engtaz
  • mojo_13
    mojo_13 Posts: 22
    edited January 2008
    I would also see how the denon does then if your not happy start looking around for an amp to drvie them. I have no experience with them but have heard good things about emotiva amps if your on a budget.
  • sjt
    sjt Posts: 22
    edited January 2008
    Add an amp. It makes a huge difference.
  • jwhitakr
    jwhitakr Posts: 568
    edited January 2008
    Go for an amp - it'll make your LSi15's sound sweet ... much better than a new receiver.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • danger boy
    danger boy Posts: 15,722
    edited January 2008
    I would take that 1K and spend it all on Oreo's :) the double stuff ones ;)
    PolkFest 2012, who's going>?
  • jayman_1975
    jayman_1975 Posts: 672
    edited January 2008
    I would take it and spend it on the biggest, fattest speaker cable he can find. When your cables are as heavy as your speaker...you are good to go.:D
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • brittle
    brittle Posts: 37
    I have tried them with the denon and they sound very good, I assume with a quality 2 channel amp they will sound awesome. I've yet to decide on an amp, will post when purchased, thanks for the input.
    Brittle
    Polk LSi-15 front
    Polk LSi-15 rear
    Polk PSW1000 sub
    Polk LSiC center
    Sony PS3
  • ben62670
    ben62670 Posts: 15,969
    I would hunt for a used Adcom GFA-555. You can get these on Audiogon.com for about $350. They work great. Just set your front speakers to large, and the rest to small. The load taken off your AVR for the left and right will boost the rest sufficiently. If that doesn't do it for you sell the Adcom for what you paid for it. You lose on shipping, but you can take that money, and get a 5-7 channel if you feel the need. One thing that you haven't mentioned is what are the rest of your speakers?
    Ben
    Ben
