Wires for RTI A7 w/amp
RussKing
RussKing Posts: 3
Will standard 12 guage CL3 in-wall wire be sufficient to wire these speakers and a moderate amplifier? I know nothing about this stuff and my home builder is looking for some input. Thanks!
Post edited by RussKing on
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2008
    What is the length of wire needed and how much power does the amp provide(per speaker)?
  • RussKing
    RussKing Posts: 3
    edited January 2008
    Honestly, I haven't bought the amp yet, and don't know anything about them. I'm trying to upgrade with my new house. I mentioned to the builder after studying this forum that I would likely need to add an external amp and he is worried that the 12 guage wire isn't enough to handle 150-300 watts. The length of the wire is probably 35-40 feet time you calculate it going up one wall, over to the closet and down the wall in the closet.
    I really appreciate your help. The sheetrock is being installed at the end of the week.
  • ShinAce
    edited January 2008
    12 gauge will be more than enough. 14 would do it, but 12 let's you get a bigger amp later on.
    Note to self, do not start a sentence with a number. I hope that's legible.
