If ICs matter...
mhartman29
... and they affect the sound quality of your system, what affect does using Y cables to split the signal have on the system? Especially, if you aren't using high quality y cables -- do they exist?
Sorry if this is a silly question, but I've been pondering using y cables to split the L & R signals coming from my preamp so that I can feed the LFE into my subwoofer. The reason I have to try this method is that my preamp (Emotiva lmc) does not send LFE output to the subwoofer output when the speakers are set to LARGE. Setting my speakers (RT3000s) to small have a negative impact on the soundstage, imo, so that isn't a viable option for me.
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Post edited by mhartman29 on
Added a splitter is adding a connection, a source of signal loss. Generally, this is of little concern. The loading on the preamp won't be significant. You should just try it and see considering the cost involved.
Where can one find higher quality y-cables to minimize the signal loss? Or will any type (radio shack) suffice?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Ultra speaker cables -
The length of the cable is not really a factor, so you're just looking for decent connectors. Any splitter will suffice.
mhartman29 wrote: »Where can one find higher quality y-cables to minimize the signal loss? Or will any type (radio shack) suffice?
don't know if higher-quality will make that much of a difference on a y cable, but audioquest makes one. -
Mhart - See if your LMC sub function has a setting for enhanced or somthing similiar.
I have the MMC. It has an option under speakers - sub - enhncd.
In this mode, you can set speakers to large and the sub will run always for movies and music.TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII -
jabrax, unfortunately, it does not. Under speakers --> sub my only options are On or Off. So far I love the LMC, but it is making it very hard to get my SW hooked up properly.Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Parts Express has some nice y-cables:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=181-692
But I'm not sure what you want to do will work well, as you will only be feeding the sub bass from the right or left channel. And it will not get the info from the LFE channel. -
I make them, and sell them.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
According to emotiva, when the speakers are set to large and the subwoofer is off, then all lfe effects are directed into the front main speakers. So, that is the rationale behind the setup.
Kex, I could try it out the Polk way. I would be interested in trying this method out, if it were not for the expense. An extra stereo pair of Signal Ultras would be $120 plus.Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
I think I would rather use some Home po-po 12 guage speaker wire and do it the Polk Way rather than a splitter but either way will work, since its just a "trial" I would not dump alot of dough into the splitters, at least not initially, if you like it, then I am sure someone will sell you a higher end splitter for a bit more tweaking.
RT1 -
If that was me and I couldn't do what you are wanting to do,I would dump it in a heartbeat and get a real pre/pro.No offence ment.HT SYSTEM-
lsi 9's -
you could buy an Outlaw ICBM, bass management problems with any system over.
RT1 -
Signal Cable here, call Frank and he'll make you a custom set of Y connectors. I purchased a pair for my old bi-amp set up and they are awesome. They DID NOT affect the signal quality. I believe they were like $75 well worth the quality.
