Denon 2910 DVD question
NeilGabriel
NeilGabriel Posts: 1,487
edited January 2008 in Electronics
I am looking to pick up a used model. The owner lists it as upconverting to 1080p. Is this accurate. The Denon website does not give the upconversion (at least as far as I could see). Thanks.
Post edited by NeilGabriel on
    billbillw Posts: 7,594
    edited January 2008
    Upscales to 720p or 1080i. Look at the product sheet at the Denon Archive.
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2008
    ^^ What Bill said, I had the DVD-2910.
  • NeilGabriel
    edited January 2008
    steveinaz wrote: »
    Steve.....So, setting aside that the owner is wrong....and he just assured me he was not....is it worth picking up this unit for $200. I have a $250 panny right now, and it works very well....but then again, I haven't done any a-b comparisons with it. I have an HDTV that upconverts.....and I don't care about SACD or DVD-Audio. Thanks
    edited January 2008
    Which Panny do you have? The S97 was (and still is) a great unit, every bit as good as the Denon in the video output department. Unless you want SACD or DVD-A, you're probably better off putting your money towards a Bluray.
  • NeilGabriel
    edited January 2008
    billbillw wrote: »
    That's the one. I also have a newer one with HDMI as well (77 I think) that is not nearly as good. Thanks.
  • steveinaz
    edited January 2008
    Bill hits it again--if it's an S97, you've already got a very good player. Having said that, the 2910 is definitely a bargian at $200--provided it's in good shape. The 2910 puts out 1080i/720p/480p over HDMI. There is no 1080p output.
