Polk PSW10
Serendipity
I heard this sub at Circuit City the other day and was impressed by its sound quality. I am considering this sub for a secondary room system, with Polk RTi6 bookshelf speakers as the mains. Would this be a decent sub for a small system, or should I get something bigger? And will the sound match well (even though the Polk PSW10 is part of the Monitor series and the bookshelfs are part of the RTi series)?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
I have the PSW10 hooked up in my bedroom paired with some older Klipsch bookshelves and am pretty pleased with it. I don't think a sub has to be matches with the rest of the speakers so I wouldn't worry about it being a good fit for the RTi's. There's certainly better subs out there but if you could get it cheap enough I think there's a good chance you'll be happy with it.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
That should work just fine.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Thanks,
I'm just looking for a good sub for music (not loud or boomy by any means).polkaudio RT35 Bookshelves
same here. I was looking for something for my new set up including some TRi A7's wonder if it is even needed?
Not sure, I was considering going with the RTi6's without a subwoofer but I find that a sub fills in the low end nicely (when turned way down) so that it blends in with the music.polkaudio RT35 Bookshelves
