Just bought Monitor 30s, and PSW12!
c_corie
c_corie Posts: 138
Using a newer, but lower end Onkyo surround receiver, where should i set the crossover on the receiver, to 60 or 80, i know the monitor 30s go down to 55, and start to drop off around 62 or 63 i think, so where should i set it? I tried 60 and that sounded cleaner then 80, but thinner as well, so....am i missing a lot of sound if i keep it 80, will there be a big gap?
Post edited by c_corie on
  • tcrossma
    tcrossma Posts: 1,301
    edited January 2008
    Go for 80. Let the sub do what it does best. Make sure you've calibrated the sub's volume level, position in the room, and phase to try and clean up the boomy bass that you might have been hearing before.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • VSchneider
    VSchneider Posts: 443
    edited January 2008
    c_corie wrote: »
    You are likely to miss more with 60 Hz crossover, since the higher it is the more the small bookshelves must be able to cover. At 63Hz Monitor 30 is already down by 3dB.
  • c019740
    c019740 Posts: 11
    edited January 2008
    You can never go wrong with 80. I think you will be please in the long run.
  • jazzisnumberone
    jazzisnumberone Posts: 53
    edited January 2008
    80 is the way 2 go. have fun..
