Best choice center channel
beatlefan
beatlefan Posts: 3
edited January 2008 in Speakers
Hello,
I have a pair of monitor 5's that I am using as front speakers. Which center speaker would be the best match for the monitors, CSI3, CS2, or CSI
A4? I know that Polk recommends the CSi5's but these are not easy to find. Any recommendations are appreciated.
Thanks!
Post edited by beatlefan on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited January 2008
    I don't know of any center channel that will be an exact match to your monitor5s...
    The CSi5 is a fine center channel. But you'd probably be just as well off with a CS400, CSi40, or another older center if you can find one.
  • beatlefan
    beatlefan Posts: 3
    edited January 2008
    Thanks for the response. I guess I'll try to find one of the center speakers you recommend.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Are you good with wood working?
    Where are you located approximately?
    Welcome to Club Polk
    Ben
    Ben
  • beatlefan
    beatlefan Posts: 3
    edited January 2008
    Ben
    Thanks, but constructing a center speaker is not something I would attempt.
