Tuner Recommendation
kitjv
I am looking for a tuner to integrate into my 2-channel system. Unfortunately, I live in an area with relatively few FM stations and, as of yet, no HD stations. Sensitivity would be a critical factor to pick up weak signals. Also, compatibility with a satellite radio receiver and HD signals would be desirable options.
Thank you for your help.
check out this site for tuner info.
http://www.fmtunerinfo.com/
Also check out this site to find all the FM stations near you.
http://www.radio-locator.com/
The problem you have is that almost all good FM tuners were made before 1990. The tuners in recievers today really suck and probably cost about $2.00 and are after thoughts. That's why I think many people in this club don't like FM tuners because they never heard a good FM tuner and antenna set up. There are some good new tuners out there but they will cost over $500. Read the web site and look on ebay for some used tuners. Get some RS rabbit ears, $10, and see what your FM reception is. How far are from the big city? -
Most decent AVR's come with ability to tune XM or Sirius. This and another $129 a year and you get around 150 channels of the absolute best radio you can ever ask for.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
I have heard some favorable comments on the Rotel RT-1084 which is both HD & Sirius compatible. Any thoughts?
I am about 180 miles from Portland, OR. However, we do have repeater stations here in town. -
Scott, Sherwood, Fisher in tube units, McIntosh in SS or tube. Many good to excellent models at all price points, mono or stereo.
I have a Parasound that really pulls em in..
I have a Nakamichi that does well, and I`m going to get the mother of all tuna`s...Magnum Dynalab..
With the ST-2 indoor/out door antena..
They make some great tuna`sand some equally great antena`s
Check out Audio Advisor for some great deals on FM antena`sCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Onkyo made some great DX'ing tuners in the late 80's/early 90s. The 9090II is probably one of the best (at least among ones that regularly come up for sale).
(In case you were confused, DX'ing means pulling in stations from really far away. Usually requires a big roof mounted antenna with a rotor if you want to get really good reception from 100+ miles away. -
The Sangean HDT-1X is a good HD radio for about $250.
Here is more information on it and other FM information.
http://ham-radio.com/k6sti/hdt-1x.htm
150 miles is to far to get FM.
Check out the radio locator with your zip code. -
FWIW, one fellow at AK wasn't too impressed with the sound he got from the Sangean:The Sangean HDT-1X is a good HD radio for about $250.
http://www.audiokarma.org/forums/showthread.php?t=143519&highlight=sangean -
mhardy6647 wrote: »FWIW, one fellow at AK wasn't too impressed with the sound he got from the Sangean:
I agree with the review that you need a strong signal to get the HD signal. But I found the analog signal to be very quiet. The background noise was very low.
Remember it doen't cost that much, less than $250. -
the fmtunerinfo website is a great source as already recommended. If you like a vintage look consider a vintage Sansui. They made great tuners back in the day and some of them can be had for relatively cheap and will significantly outperform many newer units. Some of their more popular and impressive vintage models have a following and (like the 919, 9900) can be expensive or very expensive (TU-X1) however.
Are you in So. Oregon or East of the Cascades? If in the Bend area, there are a few good stations nearby. You may need a rooftop antenna with a rotor rather than rabbit ears to pull in a good signal, or go the satellite radio route. If you have DirecTv, they have lots of stations on that too, no tuner needed. While not HD or satellite radio capable, the old Carver tuners have excellent FM sections. The TX-2 and TX-11 are good ones. Can be had for $140 or much less. I got a TX-2 for $25. Marantz also made some good tuners. -
for older tuners.. which are usually pretty good when used with an good antenna.. look at Sansui and Pioneer. plus they sound really good too.PolkFest 2012, who's going>?
Also, both Dish Network and Directv offer packages that include satellite radio feeds with your subscription.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
