blue ice amp rti10
xterra77
xterra77 Posts: 47
edited January 2008 in Speakers
Does any one know if i can use the new technical pro Blue ice amp to power my new RTi10's along with my HK for home theater or is this amp too cheap/or strong.
Post edited by xterra77 on
  • michael_w
    michael_w Posts: 2,813
    edited January 2008
    I dont know a lot about the amp but it looks pretty cheap to me. PA or DJ amps aren't usually the best for sound quality, but rather pumping out as much wattage as possible for little cash. 350 watts a channel isn't too powerful for your RTi10's, so not much need to worry there. Is there any way you can try it out locally or do you have to get it off ebay or some other online source?
  • xterra77
    xterra77 Posts: 47
    edited January 2008
    I thought so,
    i will be saving some money for my trip to NY.
    wil look for an amp there.
    We in montreal do not have much choice and if we do
    the prices are very steep tks.
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    If youre just powering the 10s, consider outlaw audio M2200 monoblocks. They perform very well, you can stack up to 3 of them and they dont get too hot either. Worth a look.
  • michael_w
    edited January 2008
    You can find some good deals on used equipment in Quebec at a site called Canuck Audio Mart. Check it out - there's always tons of great gear like bryston, classe, nad, parasound, b&k, rogue, linn, etc...
    ASL wave 8's for $300? http://www.canuckaudiomart.com/details/78124-asl_wave_8/
    Careful with duties & taxes if you bring gear across the border. It could take a great deal and end up costing you more than if you purchased it in Canada.
