Speaker Choice
gbrynan62
gbrynan62 Posts: 3
edited January 2008 in Speakers
Looking to upgrade my home theater with new equipment. I've decided to budget moderately (ie: under $5k for speakers and receiver), so I want to make sure my choices are sound. I'm looking at the following combination of speakers in a 14 x 18' room.
1. RTi A7 (2)
2. CSi A6
3. TC60i (2 rear ceiling surrounds)
4. TC65i (2 side surrounds)
5. DSW Pro 400 subwoofer.
My choices for a receiver are the Denon avr-3808ci or the avr-4308 ci.
Looking to find out if:
a. my choices are compatible.
b. my choices are not "overkill" for a room of this size.
c. anyone has other suggestions for a comparitively priced system.
The video portion of my setup will be done next year.....when more funds are available!
Post edited by gbrynan62 on
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2008
    Welcome to Club Polk! I think you will have one slamming system when it is all together. I don't believe in "overkill", if you have the room & the money to do this, go for it!
