Component Video Switch
Pablo
I'm looking for a component video switch to be able to hook my xbox (old one), and my PS3 into one input. I found a couple of cheap ones out there, but I'm worried about loss of picture quality (especialy blue-ray movies).
Any suggestions would be appreciated.
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
RTi-70 Fronts
FXi-30 Surrounds
Csi-40 Center
PSW350 Sub
Denon DVD-2910
I'm using an Impact Acoustics component matrix switcher for all my sources, and I don't see any loss with HD test patterns. They're sometimes branded as "Cables To Go" instead of Impact Acoustics, but they're the same switch.
Hit Amazon and search for "Cables To Go - 40324 - 3-Play Component Video Digital Audio Selector" and that should do what you need.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
thanks alot. I'll check those out and let you know what I think. Thanks.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
Csi-40 Center
PSW350 Sub
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
I picked one up at RadioShack (which I usually turn my nose up at), and it performed better than any $100 plus switch that I tested. The RS model can be had for about 25 bucks!THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
