WTB.....Power cord
gwh
gwh Posts: 1,451
edited January 2008 in Wanted (WTB) Classifieds
For a Sonance amp, I've got it hooked up with what I had on hand and I'm pretty sure it is a power cord for a computer:eek:
3ft should do it.
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • ESavinon
    ESavinon Posts: 3,066
    edited January 2008
    Signal Cable sells a very good power cable for a very reasonable price.
    If you want to go all out, get a shunyata or ps audio power cable for more $$$.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    I use a Signal Magic Power cable on my Spectral. It really lowers the noise floor.
  • gwh
    gwh Posts: 1,451
    edited January 2008
    Signal power cord or something comparable would do, I don't need anything exotic and overpriced.
    Thanks,
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • dcarlson
    dcarlson Posts: 1,740
    edited January 2008
    I've had success with Cardas. If you want to go DIY, have look at DH Labs.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    PartsExpress.com is now selling AR power cord on the cheap. Shielded, 12ga, gold plated, and cheaper than I could make them.
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=181-900
    Less than $40 for a 3 footer, and $45 for a 6:eek:
    Edit
    I had to fix the link
    PE is funny about search links
    Ben
  • gwh
    gwh Posts: 1,451
    edited January 2008
    I ordered one of the AR's from PE.....Thanks for the heads up!
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • gwh
    gwh Posts: 1,451
    edited January 2008
    Follow up in case anyone is interested.
    Power cord arrived and appears to be well constructed...Very stiff...Ends fit securely.
    $37.97 + $9.49 UPS = $47.46 for the 3 footer.
    Could I have done better cheaper on a new cable? I don't know but I have no regrets.
    I can not do a comparison on other PC's since this is my first aftermarket PC purchase.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
