How does the FXIA6 match with the LSI15/ LSIC?
I was wondering how the FXIA6 matches with the LSI15 / LSIC ? Anyone have this setup?
Also, whats a cheap sub to power the LSI15?
thanks
Ken
thanks
Ken
Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
"The more time you spend researching here, the less money you will have"
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
Post edited by Gizmo99 on
The LSi and RTi (A) are two totally different speaks (tweets and X-overs), so I don`t think they would blend too well together
SVS is having a killer sale right now....outstanding sub IMOCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I have RTi 4s and FXI A4s with an LSIC and it sounds good to me. I will eventually upgrade the Rti 4s to LSI 7s.
They won't match 2 different series with different sounds. You already have a matched set of speakers.
thanks
Ken
I think that you mean amplifier to give the 15's more power, not subwoofer.
Look on Audiogon for Rotel, Parasound, Sunfire, Adcom, B & K etc. You should get at least 200wpc for power. Also if you are planning on switching over to all LSI's get a multichannel amp since all of them are 4ohm speakers.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
