RTI10's and HK AVR 247?
edited January 2008 in Speakers
I recall seeing someone posting a link to home theatre mag, where he said that the HK AVR 247 can perform slightly better than the onkyo 605's, and plus drive the RTI10's better due to its circuitry- is that true?
I am debating whether to upgrade from the onkyo 605 to 705 or get the HK AVR 247 for now and get an amp later on...
Post edited by Mauskar on
Welcome!
    edited January 2008
    edited January 2008
    Whatever you get, make sure it has pre-outs.
    edited January 2008
    thanks,
    but just want to know if i go the HK route, if the HK 247 would be enough to power the RTI's...
    edited January 2008
    Any receiver can power the RTI's. They simply won't be performing to full capacity until they have separate amplification.
    Just make sure that whatever receiver you get has preamp outputs.
  • Unknown
    edited January 2008
    edited January 2008
    :D Sorry you learned that lesson the hard way Kex! Are you going to take another shot at it?
    Kex wrote: »
    If you go the separate amplification route, I would recommend trying the cfrizz theorem of good sound: "thou shalt use a minimum of 200w per channel in thy external amplifier to drive thy speakers". I "ignored" it and tried the Emotiva rated 125w/ch and got sorely disappointed as far as raw power was concerned.
    edited January 2008
    I was in the same boat. I picked the 10's on sale and couldn't resist. My old Pioneer couldn't handle the load and didn't have front channel pre outs. I picked up a H/K 235 refurb, which is the older version of the 240/247 and ran them that way. Personally, I thought it was a little strained. I ended running my Nakamichi PA-5 on the fronts. Audio Nirvana!
    edited January 2008
    I don't particularly like your screen name, but welcome to Club Polk!
    edited January 2008
    Kex wrote: »
    The modest h/k 147, which I have, and which claims to output 50w/ch stereo or "40w/ch all channels driven", was recently reviewed and bench tested to actually output 90w/ch stereo and close to 70w/ch "all channels driven". Those results beat the same test performed on a $1,000 Sony claiming 100w/ch and a $1,700 Yamaha claiming 140w/ch!
    I would expect the 247 to be pretty convincing as an AVR but it is not without its issues (mostly to do with upscaling video and LFE output levels I think). If you do not need HDMI audio or upscaling, you may want to consider a refurbished 245 (HDMI video switching only) or 235 (no HDMI) from the official Harman Audio store on e-Bay to get the same power on the cheap ... or Ron-P's 635 that is for sale in the Flea Market.
    Do you have a link to this supposed report that measured the power outputs of different AVRs? I'd be interested in reading it and knowing which Yamaha they 'reviewed'. The implication being that your amp pumps out more than rated and 'beat' the other amps (which presumably output less than what they are rated for?).
    Thanks,
    Erik
    edited January 2008
    Its a character from one of my favorite books.
  • Unknown
    edited January 2008
  • Unknown
    edited January 2008
    edited January 2008
    Kex wrote: »
    Erik, this is a topic that you will see mentioned frequently here. The two most famous brands for measuring their power "all channels driven" are very probably NAD, and, to a lesser extent perhaps, harman/kardon. Onkyo clearly state they measure "two channels driven", so they are very honest about it. Most others imply they put out a certain amount of power "per channel", but are only measuring one or two channels simultaneously, and at a specific frequency, so it has nothing to do with real life performance (where frequencies will vary tremendously, and all channels will be driven at once). Here is a link to that review, and to an article regarding power ratings:
    h/k 147 power measurements: http://hometheatermag.com/receivers/1107rack/index5.html
    Sony STR-DA3300ES measurements: http://hometheatermag.com/receivers/1107rack/index7.html
    Yamaha RX-V2700 measurements: http://hometheatermag.com/receivers/1107rack/index9.html
    Power ratings article: http://www.soundstage.com/gettingtechnical/gettingtechnical200503.htm
    Other than the review, I can personally vouch for the fact that the modest 147 I own impressed me tremendously when compared to an entry level pre-pro and external amplifier rated at 125w/ch (blind testing in stereo mode).
    Got it, thanks.
    I have the Yamaha RX-V1800...seems like this year's models do better at achieving rated power for all 5 channels driven:
    http://www.soundandvisionmag.com/receivers/2590/yamaha-rx-v1800-av-receiver-specifications-page2.html
    Sound is great and it kicks! Still...I'm going to re-integrate my Carver M-1.0t power amp into my HT setup to drive my fronts.
    Always good to have plenty of 'headroom' eh? :D
    Cheers,
    Erik
    edited January 2008
    Kex wrote: »
    So in the first link for Harmon Kardon, if i am reading this right, all channels driven at 8ohms yielded 66.7 watts/ channel @ 0.1 distortion but in driving 2 channels it yielded 89.5 watts/ channel @ 0.1 distortion for 8ohms.
    With that in mind, something like the 247 or 347 should be able to power a set of RTI8's w/o an amp, correct?
    Sag
    edited January 2008
    Mauskar wrote: »
    Sag
    H/K makes a good unit but a stand alone amp will give you the high current that really drives a speaker to it's full potential. 200 watt rating usually insures that other key specs for the amp are up to proper levels. As far as what those specs are, other members on here would know better then I.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Unknown
    edited January 2008
    edited January 2008
    MSALLA wrote: »
    Thank you.
    As for the EMO amp, I believe the jury is still out on that one.
    edited January 2008
    :eek::D Oh ok!:D
    CATKILLER wrote: »
    edited January 2008
    Well keep saving Kex, and don't forget to watch Audiogon for a good deal. That is where I got my Sunfire Prepro. It looks brand new & does a great job & I got it for less than half of the MSRP!:D
    Kex wrote: »
    I'm not quite sure yet, Cathy. I don't really have more than $1,000 to spend on amplification right now, which is probably what I would need for a decent pre/pro and amp, since we still need a new player (probably Oppo, for SACD and DVD-A), as well as a new TV (probably 42-46" LCD). The poor wifey is being very helpful and supportive of my addiction for the moment. I am currently thinking about a used NAD (again, sorry!), or Ron-P's h/k 635 (but it sounds as though it's a bit bashed up, and most/all of my stuff is minty/like new).
    edited January 2008
    Kex wrote: »
    $1,000? You might want to consider something similar to what I've been doing with my RTi12s - pick up a factory-refurbed HK 347 on EBay for about $280, a used Carver M-500 for about $250, and a Carver M-500t for about $320 or so. Bi-amp the Carvers, using the M-500 for the bass and the M-500t for the mids and tweets. That leaves about a hundred and fifty bucks to take that wonderful wife out to dinner, and you won't find a sweeter sounding setup anywhere for under a grand.
  • Unknown
    edited January 2008
    edited January 2008
    Don't forget DECENT interconnects. ;)
  • Unknown
    edited January 2008
    edited January 2008
    Kex, the article you linked to drove the amps to .1% vs .07% that's written into their specs. As you go up the distortion curve you're going to get more output. That being said they did the same thing to all the other gear too.
    If it were me and of course, I've already done it, ;), I'd go with ATs suggestion. The pre section on the HK 2 & 3xx series AVRs will be at least as good as the 147...you're already familiar and like the SQ...all you need is some vintage, affordable power...and a player...some ICs...room treatments...golden ear school...and a magic green marker :p
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    edited January 2008
    Kex wrote: »
    Thanks for the support Atomic Turtle (are you a cousin of the Atomic Kittens?!) and cfrizz.
    Nope! Don't know nothin' 'bout no Atomic Kittens! Sounds like a recipe for major mischief, though - I don't even want to think about how much trouble nuclear-powered kittens could instigate in the average household.
    Kex wrote: »
    I have been hesitant to get a more powerful h/k, since I am not sure how much of a difference it would make compared to the, apparently (according to that Home Theater Mag review in December 2007), very capable 147. I really feel that these speakers need something to make them "explode" the soundstage, as mhartman says the Emotiva combo did for his RT5000 system. I want to double, or triple the power, rather than just turn it up a little. Not for loudness, of course, as you all understand, but for control, detail, precision and soundstage.
    You're right - you definitely need more muscle to get the most out of those speakers. The difference between my old 100-WPC Panasonic receiver and my 250-WPC M-500 is orders of magnitude better. I don't know how much you spent on the speakers, but if you're only feeding them 100 watts or thereabouts you're only going to be hearing about 20 cents out of every dollar you spent. Once you get around 200 or 250 watts, you'll hear every penny. Throw another amp in the mix, and feed 'em 500 watts per channel, and you'll never leave the house again. The clarity, the detail, the soundstage... the depth, the texture... you'll find yourself listening to CDs you've heard hundreds of times, and saying to yourself, "Damn! I never dreamed it was supposed to sound like this!" Seriously. The only thing youl regret about the decision is that you didn't make it earlier.
    edited January 2008
    Ron Temple wrote: »
    I'm embarrassed to admit that I've still got some old CDs with green edges. :o
  • Unknown
    edited January 2008
Welcome!
Welcome!
